Author Topic: New Pepp 7  (Read 4415 times)
Offline JoeSh
  • Peppermint does the trick
  • Peppermint version(s): 6 and 7 (32bit) 10 (64bit)
New Pepp 7
« on: June 27, 2016, 08:49:06 am »
Absolutely loving Pepp 7. 10/10 to the team!
I've done a bit of customising-
Wallpaper: http://hdw.eweb4.com/out/1447467.html
Install Plank: http://www.noobslab.com/2014/08/install-plank-dock-and-plank-themer.html
« Last Edit: June 27, 2016, 09:08:50 am by JoeSh »
Offline JoeSh
Re: New Pepp 7
« Reply #1 on: June 27, 2016, 09:10:52 am »
Thanks GNULINUX.
I cant move away from the computer!
Re: New Pepp 7
« Reply #2 on: June 27, 2016, 09:17:38 am »
Thanks GNULINUX.
LOL .. now there's a compliment if I ever heard one  :)
Nice desktop BTW JoeSh...
« Last Edit: June 27, 2016, 09:20:24 am by PCNetSpec »
Offline JoeSh
Re: New Pepp 7
« Reply #3 on: June 27, 2016, 09:36:43 am »
Thanks GNULINUX.
8)
Offline Bloch
  • Peppermint version(s): 7
Re: New Pepp 7
« Reply #4 on: June 28, 2016, 11:34:04 am »
My eyes are sensitive to colors and I don't know why but Very nice customization!
Wonderful wallpaper!
Offline JoeSh
Re: New Pepp 7
« Reply #5 on: June 28, 2016, 04:32:25 pm »
Yeah, it's bright!!  >:( But I like it.
Thanks Bloch
Have you done any customising yourself?
Offline Bloch
Re: New Pepp 7
« Reply #6 on: June 28, 2016, 05:10:38 pm »
JoeSh: You are the artist, not me.
Thanks for the attention.
Re: New Pepp 7
« Reply #7 on: June 28, 2016, 05:23:35 pm »
Here's my desktop.  I've stuck with one of the default wallpapers just because I think Ray Bilcliff's photos are stunning  ;).
Click to Enlarge Image
Widget is: Peppermix-Dark-7-Red, Icon Theme is: Peppermix -7,  The wallpaper is Beachfront_(image_by_Ray_Bilcliff).jpg.  This is in the default wallpaper selection.  It's a photo of Whitley Bay in the North East of England.  I've installed Docky instead of Plank this time, just for a change.  The Conky set is: Gold And Grey Conky.  This is actually five separate Conky displays that have been custom positioned.  The package screenruler is very useful to do this.
sudo apt install screenruler.
Here is the Whisker Menu with Panel positioned at the top of the screen.  I've turned off: Show application descriptions in the menu Properties.  The panel is set to autohide because I'm using a laptop and real estate is at a premium.  You can see the items I've added to the Panel
The Sakura terminal has been customized to launch with a custom geometry, four tabs and screenfetch.  The terminal font and size is Teminus, 13.  The palette is xterm.
Displaying the Nemo file manager with a split screen configuration.  The font and size is Roboto Regular, 11.  The Sakura terminal is rolled up.
Offline Bloch
Re: New Pepp 7
« Reply #8 on: June 28, 2016, 05:52:58 pm »
I'm impressed!
ScreenFetch: awesome utility.
Really nice customization!
Re: New Pepp 7
« Reply #9 on: June 28, 2016, 05:58:41 pm »
Nice job JoeSh,  You've made a really sharp and crisp looking desktop - well done  8)!!
Re: New Pepp 7
« Reply #10 on: June 28, 2016, 06:58:58 pm »
Nice one Andy ..  I like the look of that conky, might need to check that out.
Re: New Pepp 7
« Reply #11 on: June 28, 2016, 10:58:45 pm »
Hi All
Nice Setups joeSH  8) and AndyinMokim  8)
I always know what I like and I can plagiarise like a Pro.  I just I wish I had some artistic flair to come up with my own ideas.
It's why I have to trawl posts like these to get inspiration  :)
Offline JoeSh
Re: New Pepp 7
« Reply #12 on: June 29, 2016, 12:19:33 am »
Thanks ZEBEDEEBOSS and hats off to ANDYINMOKUM, the conky is spot on!  8)
I've had a bit of a go at conky but I didn't really want to mess too much without knowing exactly what to do. It would be great to have a step by step to follow.  :-\
« Last Edit: June 29, 2016, 12:41:13 am by JoeSh »
Offline asheguy
Re: New Pepp 7
« Reply #13 on: June 29, 2016, 08:07:59 am »
Andy how do you use screenruler to move the conky around and find the other themes?
Offline JoeSh
Re: New Pepp 7
« Reply #14 on: June 29, 2016, 01:31:46 pm »
Hi AndyInMokum, how do get split screen in file manager?
