Author Topic: Problem installing 7 on MSI Wind  (Read 1721 times)
Offline UUUnicorn
  • Peppermint version(s): Five
« on: June 26, 2016, 11:13:48 am »
Help, please! Thank you in advance!
I tried installing Peppermint OS 7 32-bit from DVD in external optical drive onto my MSI Wind netbook, but a window opened with the information below. I don't know how to fix this.
Thank you very much in advance! BEAUTIFUL distro/release!
Unsafe Swap Space
An unsafe swap space has been detected.
This is a fatal error since sensitive data...
« Last Edit: June 26, 2016, 11:16:02 am by UUUnicorn »
Offline Timo
Re: Problem installing 7 on MSI Wind
« Reply #1 on: June 26, 2016, 11:30:55 am »
Was this the auto installation or manual?
If manual have you created a swap partition?
« Reply #2 on: June 26, 2016, 11:42:14 am »
If this is to b e the ONLY OS on the netbook, boot to the Live session desktop, then open a terminal and run:
sudo swapoff --allif prompted for a password, just hit enter.
Now close the terminal and start the installation from the "Install Peppermint 7" desktop icon.
Basically it's just found a swap partition flagged as having a hibernation state saved.
Offline UUUnicorn
« Reply #3 on: June 26, 2016, 01:41:38 pm »
Well, it seemed to install okay. When I restarted, though, the Peppermint OS splash screen appeared with the words "starting up" at the top, but it didn't go beyond it. When I hit "Enter", at the bottom of the screen, this appeared:
cryptsetup: cryptsetup failed, bad password or options?
« Reply #4 on: June 26, 2016, 01:53:36 pm »
Okay, it seems like what happened was on your previous OS you'd chosen disk encryption .. this gave you an encrypted swap partition, and explains the original error.
On a fresh install the easiest and quickest fix here would probably be for you to boot to the LiveUSB/LiveCD again, run:
sudo swapoff --allproa
then fire up Gparted and delete ALL partitions on the hard drive leaving only empty unpartitioned space.
Once applied and finished, close GParted, and reinstall from the desktop icon.
« Last Edit: June 26, 2016, 01:56:13 pm by PCNetSpec »
