Author Topic: p7, HP Pavilion G6 & nomodeset [SOLVED]  (Read 2207 times)
    • My MeWe profile
« on: June 25, 2016, 06:10:10 pm »
welp... its a no go for installation thus far on the 2011 HP Pavilion G6...
sean@hpG6 ~ $ inxi -F
System:    Host: hpG6 Kernel: 4.6.0-040600rc5-generic x86_64 (64 bit) Desktop: N/A Distro: Peppermint Six
Machine:   System: Hewlett-Packard product: HP Pavilion g6 Notebook PC version: 0690130000204610000620100
           Mobo: Hewlett-Packard model: 169B version: KBC Version 18.1A Bios: Hewlett-Packard version: F.46 date: 01/16/2012
CPU:       Dual core AMD A4-3305M APU with Radeon HD Graphics (-MCP-) cache: 1024 KB flags: (lm nx sse sse2 sse3 sse4a svm)
           Clock Speeds: 1: 1400.00 MHz 2: 1600.00 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Sumo [Radeon HD 6480G]
           X.Org: 1.16.0 drivers: ati,radeon (unloaded: fbdev,vesa) Resolution: 1366x768@60.0hz
           GLX Renderer: Gallium 0.4 on AMD SUMO2 GLX Version: 3.0 Mesa 10.3.2
Audio:     Card-1: Advanced Micro Devices [AMD] FCH Azalia Controller driver: snd_hda_intel
           Card-2: Advanced Micro Devices [AMD/ATI] BeaverCreek HDMI Audio [Radeon HD 6500D and 6400G-6600G series] driver: snd_hda_intel
           Sound: Advanced Linux Sound Architecture ver: k4.6.0-040600rc5-generic
Network:   Card-1: Realtek RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller driver: r8169
           IF: eth0 state: down mac: 78:e3:b5:67:40:5e
           Card-2: Ralink RT5390 Wireless 802.11n 1T/1R PCIe driver: rt2800pci
           IF: wlan0 state: up mac: e4:d5:3d:a7:7f:f2
Drives:    HDD Total Size: 320.1GB (16.6% used) 1: id: /dev/sda model: ST320LM000_HM321 size: 320.1GB
Partition: ID: / size: 19G used: 5.3G (31%) fs: ext4 ID: /boot size: 1.8G used: 225M (14%) fs: ext4
           ID: /home size: 274G used: 45G (17%) fs: ext4
Sensors:   System Temperatures: cpu: 46.2C mobo: 0.0C gpu: 50.0
Info:      Processes: 183 Uptime: 2 min Memory: 498.6/3427.1MB Client: Shell (bash) inxi: 1.9.17
hitting the escape to select USB boot works, but once in LiveUSB mode, using TAB to edit the install script doesn't work... Also doesn't matter if I'm trying to "Test/try out" or  "Install" Peppermint7
« Last Edit: June 26, 2016, 04:55:52 pm by spence »
 '18 Asus VivoBook
Re: p7, HP Pavilion G6 & nomodeset
« Reply #1 on: June 25, 2016, 06:38:43 pm »
Not quite sure what you're saying here Spence  :-\
Do you mean you're unable to get to the GRUB menu, then hit "E" to edit the kernel boot line ?
Are you talking about editing the kernel boot line on a LiveUSB, or an installed system ?
« Reply #2 on: June 25, 2016, 06:41:39 pm »
Hold down SHIFT at boot for the Grub menu, then press E to edit the kernel boot parameters.
    • My MeWe profile
« Reply #3 on: June 25, 2016, 06:43:09 pm »
??? I get to the Peppermint7 LiveUSB menu... where nomodeset makes no difference whether I attempt to TEST or INSTALL... why is that confusing?
 '18 Asus VivoBook
    • My MeWe profile
« Reply #4 on: June 25, 2016, 06:50:26 pm »
holding down the SHIFT key returns
ISOLINUX 4.01 debian20101016 blah blah blah
« Last Edit: June 25, 2016, 06:52:17 pm by spence »
 '18 Asus VivoBook
« Reply #5 on: June 25, 2016, 07:03:00 pm »
OK, on a LiveUSB, when you get to the Install Peppermint/Try Peppermint screen, hit the "Tab" key
You'll see some white text at the bottom that ends with quiet splash --
make that end quiet splash nomodeset
then hit enter to continue booting.
« Reply #6 on: June 25, 2016, 07:06:50 pm »
Because your original post didn't state that you were using a LiveUSB .. I'm not a mind reader, or a practitioner of remote viewing.
    • My MeWe profile
« Reply #7 on: June 25, 2016, 07:10:18 pm »
Sorry, but my original post used USB and LiveUSB below the inxi-F code.... but anyway,  this is precisely what I've attempted 15 times, as I did review my posts on previous installs before beginning today. Each time I hit the backspace to delete the -- behind quiet splash -- creates a newly repeated line... then I enter nomodeset... and am quickly back at the Install/Try graphical menu...
 '18 Asus VivoBook
« Reply #8 on: June 25, 2016, 07:17:52 pm »
So what exactly happens when you try to boot normally .. black screen ?
and what happens if you boot with nomodeset .. same ?
    • My MeWe profile
« Reply #9 on: June 25, 2016, 07:21:21 pm »
selecting "Try" ,"Install" , "Check disc" and "Boot from first drive" all quickly return me to the graphical LiveUSB menu...
doesn't matter if I've typed nomodeset in "Try" or "Install" first. Only the "Test Memory" menu option works for me.
"note to self" keep my queries "above the CODE fold" so to speak ;~)
« Last Edit: June 25, 2016, 08:09:12 pm by spence »
 '18 Asus VivoBook
« Reply #10 on: June 25, 2016, 08:25:34 pm »
Ah right it's not a black screen (graphics) issue, it's dumping you back to the "Try/Install" screen.
I'll see what I can find spence.
Just for clarity, have you checked the MD5 sum of the ISO, and tried burning it to another USB stick ?
    • My MeWe profile
« Reply #11 on: June 25, 2016, 08:41:46 pm »
yes PCNetSpec... i did verify the MD5sum...  have not yet tried another USB... i did verify that the laptop bios had all boot options enabled and i moved the three USB options to the top of the list...   :-\
 '18 Asus VivoBook
    • My MeWe profile
« Reply #12 on: June 25, 2016, 08:58:50 pm »
different LiveUSB, no difference... after a single dash appears in upper left of screen, then" press esc to change boot order" i keep getting thrown back to the LiveUSB's main graphical interface where I can choose Try or Install menu.  :-\
would my use of a much more recent kernel in p6 be an issue? 4.6.0-040600rc5-generic?
 '18 Asus VivoBook
    • My MeWe profile
« Reply #13 on: June 25, 2016, 09:04:11 pm »
when i attempt to reverify the GPG Keys, I get this:
sean@hpG6 ~/Downloads/peppermint7 $ gpg --list-keys
/home/sean/.gnupg/pubring.gpg
pub   2048R/AECF1D2F 2013-05-02
uid                  Mark Greaves (PCNetSpec) <mark@pcnetspec.co.uk>
sub   2048R/4B06BE0D 2015-05-03
sub   2048R/3606A7AD 2015-05-03
but the https://peppermintos.com/gpg-verification/ tells me i should get this:
sub   2048R/65814265 2013-05-02
which does not match... yet i eventually get this:
sean@hpG6 ~/Downloads/peppermint7 $ gpg --verify Peppermint-7-20160616-amd64.iso.sig Peppermint-7-20160616-amd64.iso
gpg: Signature made Thu 23 Jun 2016 05:35:13 AM MST using RSA key ID AECF1D2F
gpg: Good signature from "Mark Greaves (PCNetSpec) <mark@pcnetspec.co.uk>"
gpg: WARNING: This key is not certified with a trusted signature!
gpg:          There is no indication that the signature belongs to the owner.
Primary key fingerprint: 4A9F 9066 13AF ABED CFA3  92C2 E499 FD0B AECF 1D2F
« Last Edit: June 25, 2016, 09:07:16 pm by spence »
 '18 Asus VivoBook
« Reply #14 on: June 25, 2016, 09:08:55 pm »
Possible, but I'm not convinced this is a kernel issue, kernel panics normally lock the machine not kick you back to the try/install screen.
Are you saying you get the message "press esc to change boot order" on screen ? .. if so, what are you presented with if you hit escape ?
the reason I ask is that sounds like a BIOS message .. it may be best to try setting the USB stick as the first boot device .. but more and more this seems like a problem with the system reading the USB stick
Is there any chance you could try it "old school" on a DVDR ?
The important lines in the GPG key listing are the top 2 lines, which do match ;)
