Author Topic: [SOLVED] Canon iP2700  (Read 1791 times)
« on: May 04, 2016, 04:37:00 pm »
I've realised I never installed my printer, which I hardly ever use. I need to do something very similar to the 64-bit version of this:
https://forum.peppermintos.com/index.php/topic,913.msg7896.html#msg7896
but
$ wget http://cz.archive.ubuntu.com/ubuntu/pool/universe/t/tiff3/libtiff4_3.9.7-2ubuntu1_amd64.deb
--2016-05-04 22:35:27--  http://cz.archive.ubuntu.com/ubuntu/pool/universe/t/tiff3/libtiff4_3.9.7-2ubuntu1_amd64.deb
Resolving cz.archive.ubuntu.com (cz.archive.ubuntu.com)... 217.31.202.63, 2001:1488:ffff::63
Connecting to cz.archive.ubuntu.com (cz.archive.ubuntu.com)|217.31.202.63|:80... connected.
HTTP request sent, awaiting response... 404 Not Found
2016-05-04 22:35:28 ERROR 404: Not Found.
Are these packages/drivers still available? I tried installing it automatically via Printers from the menu and it gets recognised but won't print anything. Thanks...
« Last Edit: September 28, 2016, 08:16:41 am by murraymint »
Re: Canon iP2700
« Reply #1 on: May 04, 2016, 05:04:29 pm »
wget http://launchpadlibrarian.net/149178897/libtiff4_3.9.7-2ubuntu1_amd64.deb
Re: [SOLVED] Canon iP2700
« Reply #2 on: May 04, 2016, 05:59:50 pm »
Thanks PCNetSpec, that did the trick :)
I've discovered my pdf viewer (Evince) is no good though, it wouldn't print (GNOME print preview worked). What's a good one to use?
« Reply #3 on: May 04, 2016, 08:59:38 pm »
Master PDF Editor
https://code-industry.net/free-pdf-editor/
I'd include this in Peppermint if it were open source ;)
« Reply #4 on: September 26, 2016, 02:18:46 pm »
Hi, I want to install this again, in Peppermint 7 this time, but I'm getting "file not found" for the drivers. Is there any way to do this? I saw you recently helped out a user with the very similar iP2600, Mark, but he was using a 32-bit system and I'm on 64-bit. Cheers.
EDIT: the libtiff downloads but the "canon trunk" ppa is "unable to locate package", possibly because there's no version for Xenial.
« Last Edit: September 26, 2016, 02:35:51 pm by murraymint »
Re: [un-SOLVED] Canon iP2700
« Reply #5 on: September 27, 2016, 07:20:50 pm »
Just bumping this because it's not solved any more for PM7. I'm going to give this printer away to a Windows user anyway but it'd be nice to get it working one last time.
« Reply #6 on: September 28, 2016, 06:31:54 am »
Try
sudo add-apt-repository ppa:mark-pcnetspec/canon-printer
sudo apt-get update
sudo apt-get install cndrvcups-common cnijfilter-ip2700series
now set up the printer the normal way, selecting
Canon > IP2700
as the driver.
In the future, can you please not change the status of a topic marked as (SOLVED) to (un-SOLVED) just because you now want it for different version of Peppermint .. the ORIGINAL issue WAS solved for Peppermint 6 as asked, it doesn't become UNSOLVED just because you add another Peppermint version to the mix ;)
(Ideally you'd have changed the title here to include "Peppermint 6", and started a new topic for Peppermint 7)
« Last Edit: September 28, 2016, 07:03:01 am by PCNetSpec »
« Reply #7 on: September 28, 2016, 07:05:23 am »
Thanks, it installed! Now I'm wondering if there's any way to put it through a cleaning cycle in Linux, because I can't find one. The test page has sections missing/very faint.
« Reply #8 on: September 28, 2016, 08:08:28 am »
No idea .. is there nothing in the driver properties for print head cleaning ?
and is the driver issue now (SOLVED) ? .. if so, can you please stop adding new issues to this topic, mark it solved, and start a new topic about head cleaning.
« Reply #9 on: September 28, 2016, 08:17:34 am »
Yeah, the driver's solved but the only maintenance option is to print a test page. I'll not bother starting another topic because I don't have a lot of time to sort this out.
