Author Topic: Updating Pepperflash After Fresh Installaion [SOLVED]  (Read 13385 times)
« on: April 28, 2016, 09:42:17 am »
Hello Peppermint!
Did a fresh install of Peppermint today, but I can't seem to get Pepperflash plugin to update.  I get this message instead:
I know I can download Chrome but I'd prefer to use our open source Chromium browser on this computer if I can.  (Even my Opera browser begins as an open source installation through use of the terminal.)
Any suggestions would be appreciated.  I did go to the Debian link that was mentioned in the message above, but I learned nothing more there than I had learned here concerning Pepperflash.  ;)
Thank you,
perknh
« Last Edit: April 28, 2016, 04:29:16 pm by perknh »
Re: Updating Pepperflash After Fresh Installaion
« Reply #1 on: April 28, 2016, 09:56:05 am »
Hi perknh
Try this link http://ubuntuforums.org/showthread.php?t=2322426&s=9ac6506213f87fbe5425bcfefd461bbc&p=13479267#post13479267
it appears you are not the only one with the same problem today
« Reply #2 on: April 28, 2016, 10:11:24 am »
Thanks for trying, zebedeeboss!  I ran the command, but still nothing.  I got this result:
« Reply #3 on: April 28, 2016, 10:18:22 am »
Hi perknh
We tried  :)  lets wait for the techie Guru's now, who will decipher the gobble-de-gook for us  :-\
« Reply #4 on: April 28, 2016, 10:20:58 am »
Did you try uninstalling and reinstalling Pepperflash to get the latest version?  Just a thought.
« Reply #5 on: April 28, 2016, 10:54:18 am »
I've tried now, scifidude79, but still no luck.  Thank you for the idea.  ;)
Offline GNULINUX
« Reply #6 on: April 28, 2016, 11:30:14 am »
What's the output from:
sudo apt-get install pepperflashplugin-nonfreeDoes it say "pepperflashplugin-nonfree is already the newest version" or does this installs it for you?
Greets!
« Reply #7 on: April 28, 2016, 04:28:20 pm »
Greets!
You're absolutely right, GNULINUX!  I've got the latest version!  ;)
The command to get the status did not work for me either.  Thank you for this new command,  ;)
perknh
Offline GNULINUX
« Reply #8 on: April 28, 2016, 05:03:23 pm »
Glad you got it working!  :)
After some more research: You're right, something is broken...
On both my machines "sudo apt-get update" returns the same output: "W: There is no public key available for the following key IDs: 1397BC53640DB551"
They have both pepperflashplugin-nonfree installed and are on version 20.0.0.306 in Chromium.
If I run "sudo apt-get install pepperflashplugin-nonfree" i get "pepperflashplugin-nonfree is already the newest version".
If I run "sudo update-pepperflashplugin-nonfree --install" I get "ERROR: failed to retrieve status information from google : W: There is no public key available for the following key IDs: 1397BC53640DB551"
Question:
Do we really have the newest pepperflash version (Google Chrome is on v.21.0.0.216) or has this something to do with Google dropping support for 32-bit?
At least you can watch flash-videos now!  ;)
Re: Updating Pepperflash After Fresh Installaion [SOLVED]
« Reply #9 on: April 28, 2016, 05:30:25 pm »
Yeah, there's nothing we can do about this .. Google need to fix their package signing.
I can tell you how to MANUALLY rip out pepperflash from the latest Chrome and apply it to Chromium .. or you can
a) either switch to Chrome .. which you'll probably still have to manually install (for the same signing reason)
b) switch to Firefox
c) wait until Google fix their package signing
you can see a list of other broken packages (because the maintainers haven't got the right signatures) here:
https://wiki.debian.org/Teams/Apt/Sha1Removal
though I don't know how up-to-date that list is
Something tells me Google propbably won't fix their package signing until the next Chrome release.
Offline GNULINUX
« Reply #10 on: April 29, 2016, 12:30:46 am »
^ Thanks for the extra info!  ;)
« Reply #11 on: April 29, 2016, 02:17:35 pm »
Out of curiosity, does anyone know how Firefox deals with Flash?
Pepperflash plugin doesn't work with Firefox, and I've also read that Firefox wants nothing to do with Flash.  But Firefox would still have to deal with Flash in one way or another, I'd think.  :-\
perknh
« Reply #12 on: April 29, 2016, 02:33:18 pm »
If I remember rightly there's a third-party version of the plug-in that gets Flash from chrome and puts it into Firefox. You don't have to install chrome.
sudo apt-get install flashplugin-installer
if you want to try it.
« Reply #13 on: April 29, 2016, 02:51:57 pm »
Hello murraymint.
This will be for a friend's 32- bit computer if he ever needs it.  I removed and purged Pepperflash from his computer today, since he can't run Chromium or Chrome on that old computer any longer.  Now, if he needs Flash, I'll know what to do.
Thank you,
perknh
« Reply #14 on: April 29, 2016, 03:00:43 pm »
Hi perknh
Why can't he use Chromium? Have you thought about something lighter, Midori for instance?
