Author Topic: There is no public key available for the following key IDs (SOLVED)  (Read 9165 times)
I get this message after updating, and do not know if it is important or not.
My Peppermint 4 installation is fast, and seems to be working well, but I suspect something could be wrong.
I began getting this after I started searching for PPAs to update my Chromium browser -- which I know now was a bad idea.  I tried too many times too, so I get a message about duplicates also.
I don't know if I should clean this up, or even how to do so, or if I should re-install Peppermint 4, or just leave well enough alone.  As I said, my Peppermint 4 installation seems to be working fine.  It's this message below that disturbs me.  This is copied from my terminal after I run sudo apt-get update:
Thank you,
perknh
« Last Edit: May 28, 2014, 07:54:06 am by perknh »
Re: There is no public key available for the following key IDs
« Reply #1 on: May 24, 2014, 09:07:50 am »
Post the contents of
gedit /etc/apt/sources.list
and please put the output between spoiler tags.
« Reply #2 on: May 24, 2014, 12:17:08 pm »
Also my terminal said this:
$ gedit /etc/apt/sources.list
** (gedit:2207): WARNING **: Could not load theme icon user-bookmarks-symbolic: Icon 'user-bookmarks-symbolic' not present in theme
I imagine you want me to go in there and delete the duplicate massages.  But I won't do a thing until you say so.
Thank you,
perknh
« Last Edit: May 24, 2014, 12:23:11 pm by PCNetSpec »
« Reply #3 on: May 24, 2014, 12:28:05 pm »
Gtk worning can be safely ignored.
OK, run:
sudo cp -v /etc/apt/sources.list /etc/apt/sources.list.bak
sudo gedit /etc/apt/sources.list
scroll to the bottom and comment out the bottom 2 lines .. so the file ends with:
## Uncomment the following two lines to add software from Ubuntu's
## 'extras' repository.
## This software is not part of Ubuntu, but is offered by third-party
## developers who want to ship their latest software.
# deb http://extras.ubuntu.com/ubuntu raring main
# deb-src http://extras.ubuntu.com/ubuntu raring main
# deb http://security.ubuntu.com/ubuntu/ raring-security multiverse universe restricted main
# deb http://us.archive.ubuntu.com/ubuntu/ raring-proposed multiverse main universe restricted
SAVE the file and exit gedit .. back in the terminal run:
sudo apt-get updateany errors now ?
« Reply #4 on: May 24, 2014, 01:03:57 pm »
There was a word main after what you copied.  I tried it both ways, with the word main, and without the word main --but still the same results.
Nothing seems different.  These are my results:
« Last Edit: May 24, 2014, 05:34:49 pm by PCNetSpec »
« Reply #5 on: May 24, 2014, 01:22:28 pm »
dunno what you mean by "main"
post the contents of
gedit /etc/apt/sources.listagain
« Reply #6 on: May 24, 2014, 05:07:43 pm »
Requested contents in spoiler below.
« Last Edit: May 24, 2014, 05:34:19 pm by PCNetSpec »
« Reply #7 on: May 24, 2014, 05:29:41 pm »
Run:
sudo gedit /etc/apt/sources.listand delete the last line that reads:
SAVE the file and exit gedit.
Back in the terminal run these commands in sequence:
sudo mv -v /var/lib/apt/lists /var/lib/apt/lists-oldthen
sudo mkdir -p /var/lib/apt/lists/partialthen
I'm going to edit your last 2 posts .. from now on if you are asked to post any long output, please surround it with spoiler tags.
you can do this by highlighting all the text that you want in the spoiler, then whilst it's highlighted hit the [Sp] button.
« Reply #8 on: May 24, 2014, 06:22:30 pm »
Thank you, PCNetSpec.  I forgot about using the spoiler tags, and I apologize about that.  I think I followed your spoiler tag request correctly this time.  I see two sets of three spoilers, and I don't have a clue what this all means.  But it looks a lot neater to me in Preview.
I started over again, as I believe you would have wanted me to, and what you see above is what I got from the terminal after running sudo apt-get update.
Thank you,
perknh
« Last Edit: May 25, 2014, 03:33:38 am by PCNetSpec »
« Reply #9 on: May 25, 2014, 03:46:54 am »
Run:
sudo apt-key adv --recv-keys --keyserver keyserver.ubuntu.com 40976EAF437D05B5then try:
sudo apt-get updateagain.
Use of spoilers...
Try clicking the "Modify" button on one of the posts I've fixed .. and take a look at how I applied the spoiler tags.
like this
[spoiler]text to be hidden by the spoiler goes here[/spoiler]
« Reply #10 on: May 25, 2014, 04:43:10 am »
PCNetSpec,
You fixed it!   :)
From what I can see, my Peppermint 4 now updates normally.
If I may ask, how did I mess things up, so that I had to be dug out of this mess?
And, do you, and Mac, just whip this code off the top of your heads?
This is like magic to me.  Both of you guys seem to pull rabbits out of hats with mysterious stings of code.  How does you recognize what to do?  And, then, how do you know what string of code to run in the terminal?  And where does this code come from anyway?
I'm astonished by all of this.
And thank you for teaching me about spoilers.  I had never even known about them before yesterday.
perknh
Here's the output. (I did asterisk out a family member's name.)
« Reply #11 on: May 25, 2014, 04:55:49 am »
IT support rarely get to know that .. we only see the aftermath ;)
Voodoo, a bit of chanting around a fire, some strong cactus juice, then we lick a few frogs and the solution just comes to us in a dream  :o
(for some reason there's always the sound of an eagle call in  the background .. even in the UK where there are no eagles  :-\)
« Last Edit: May 25, 2014, 05:14:46 am by PCNetSpec »
« Reply #12 on: May 25, 2014, 05:19:43 am »
Thank you, PCNetSpec,
I want that experience too!
 8)
« Reply #13 on: May 25, 2014, 05:30:29 am »
No problem :)
Please remember to mark the topic (SOLVED)
you can do this by editing the FIRST posting in this topic and changing:
Subject: There is no public key available for the following key IDs (SOLVED)
Thanks in advance.
« Last Edit: May 25, 2014, 06:05:46 am by PCNetSpec »
« Reply #14 on: May 25, 2014, 06:07:47 am »
Quote from: PCNetSpec
Quote from: perknh
You'll need to hook up with a good frog dealer then :)
PS. NOT Jim Henson .. his frogs are rubbish and taste vaguely of pork when you lick them  :P
« Last Edit: March 14, 2015, 05:49:48 pm by PCNetSpec »
