Author Topic: Change clock to 12 hour format? (solved)  (Read 3813 times)
Offline _tuter
  • 18 yrs old - Distro Hopper - Peppermint Lover
  • Peppermint version(s): Peppermint OS 6!!
« on: May 23, 2014, 05:46:34 pm »
I was wondering if anyone knew how to change the format of the clock to 12 hour instead of 24??
Thanks in advance,
_tuter
« Last Edit: May 23, 2014, 06:17:40 pm by _tuter »
:) _tuter :)
Re: Change clock to 12 hour format?
« Reply #1 on: May 23, 2014, 06:05:31 pm »
Right-click the clock .. select "Digital Clock Settings"
Change:-
Clock format from
%R
to
%I:%M:%S %p
if you don't want the seconds
%I:%M %p
or you could try just
%r
if you want to see ALL available options, run this in a terminal
man 3 strftime
Offline _tuter
« Reply #2 on: May 23, 2014, 06:17:24 pm »
Thanks!! I knew where to go, just didn't know the correct input to change it.
Thanks again,
_tuter
:) _tuter :)
Re: Change clock to 12 hour format? (solved)
« Reply #3 on: May 23, 2014, 06:41:20 pm »
No problem .. thanks for marking the topic solved :)
