Author Topic: Fix screen tearing issue on Intel graphics chips  (Read 1286 times)
Offline marcdutonkin
« on: April 04, 2016, 05:12:39 pm »
Hi all, I applied the fix posted by PCNetSpec on November 25, 2015 in the "User Submitted Tutorials" section. It works well on my NUC :) as long as the screen is not put to sleep.
When the screen is put to sleep, the screen tearing issue reappears after screen wakeup  :(, and to fix it, the sole solution I know is then either to logoff then login again, or to reboot the NUC.
Do you know a better way to handle this situation, such as a means to set again the option "TearFree" to "true" in an automatic way  ?  :-\
