Author Topic: Wifi dropping with out recovery (Solved)  (Read 1773 times)
Offline Brotherred
  • No0b
  • Peppermint version(s): Pep 8 on 386, Pep 10 on AMD 64
« on: April 02, 2016, 07:29:42 pm »
This I am sorry to say is a fresh install on my laptop. That fact is a grievous note for me... Anyway my Wifi that other seems to work perfectly drops at random and I can not recover it with out restart. The Wifi works great and automatically on login. So I have no idea why it disconnects like it does. And also not having attempted to hack the suspend/ resume on this instance further can not see why it fails at all.
*** ~ $ inxi -n
Network:   Card-1: Ralink RT2500 Wireless 802.11bg driver: rt2500pci
           IF: wlan0 state: up mac: 00:11:09:ae:f5:02
           Card-2: Silicon Integrated Systems [SiS] SiS900 PCI Fast Ethernet driver: sis900
           IF: eth0 state: down mac: 00:0c:76:f6:b7:5c
*** ~ $ inxi -M
Machine:   System: AVERATEC product: 6240 Series version: 0101
           Mobo: N/A model: N/A Bios: American Megatrends version: A1011SMS V1.10 12/06/04 date: 12/06/2004
At least I haven't done anything really stupid with it yet. Regards.
« Last Edit: April 04, 2016, 02:30:30 pm by Brotherred »
Re: Wifi dropping with out recovery
« Reply #1 on: April 03, 2016, 05:15:25 am »
You might want to give WiCD a go instead of networkmanager
Do you need help with this .. if so please post the output from:
uname -aand
sudo apt-get remove -s network-manager
Offline Brotherred
  • No0b
« Reply #2 on: April 03, 2016, 12:22:36 pm »
Thanx for asking. I am quite sure that I have no idea what I need help with...
*** ~ $ uname -a
Linux SnappyPenquen 3.16.0-67-generic #87~14.04.1-Ubuntu SMP Fri Mar 11 00:26:36 UTC 2016 i686 athlon i686 GNU/Linux
*** ~ $ sudo apt-get remove -s network-manager
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
  libreadline5 wpasupplicant
Use 'apt-get autoremove' to remove them.
The following packages will be REMOVED:
  network-manager network-manager-gnome
0 upgraded, 0 newly installed, 2 to remove and 0 not upgraded.
Remv network-manager-gnome [0.9.8.8-0ubuntu4.4]
Remv network-manager [0.9.8.8-0ubuntu7.2]
*** ~ $ sudo apt-get autoremove
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Regards
« Reply #3 on: April 03, 2016, 01:19:05 pm »
Okay, first let's grab what you'll need to reinstall networkmanager if things go wrong
mkdir ~/reinstall-nmthen
cd ~/reinstall-nmthen
apt-get download network-manager network-manager-gnomeif that lot went without error, carry on below
sudo apt-get install wicd-gtk python-wicd wicd-daemonthen
sudo apt-get remove network-manager network-manager-gnomenow try connecting with wicd (if there's no system tray icon for wicd yet, you may need to start it from the menu, or reboot)
to undo
sudo apt-get remove --purge wicd-gtk python-wicd wicd-daemonthen
sudo dpkg -i *.debthen if necessary reboot.
« Last Edit: April 03, 2016, 01:20:50 pm by PCNetSpec »
Offline Brotherred
  • No0b
« Reply #4 on: April 03, 2016, 04:37:51 pm »
I'm sorry I just don't understand this first part TO DO
I just installed those. Why am I removing them?
« Reply #5 on: April 03, 2016, 04:41:27 pm »
It says "to undo" if you want to go back to how it was before.
Offline Brotherred
  • No0b
« Reply #6 on: April 03, 2016, 05:29:16 pm »
Ok, that should have been obvious. The wicd applications seem to be working fine.
« Reply #7 on: April 04, 2016, 06:43:48 am »
Good news ! :)
