Author Topic: trouble installing Peppermint 4 (Solved)  (Read 2713 times)
Offline Lance.lauren09
« on: May 22, 2014, 09:51:09 pm »
Hi,
trying to install on a Dell Optiplex GX260
When I try to install from cd it always comes up with this prompt.
ISOLINUX 4.02 debian-20101016 ETCD
Not sure what this prompt means and if I am still able to install Peppermint OS on this computer.
This is the same CD that I have been using to install to other machines.
thank you in advance
« Last Edit: May 23, 2014, 09:00:15 pm by Lance.lauren09 »
Re: trouble installing Peppermint 4
« Reply #1 on: May 22, 2014, 10:04:41 pm »
If it ends with a:-
Boot:
prompt .. try typing:-
live
and hitting enter
« Reply #2 on: May 23, 2014, 12:46:59 pm »
There is no cursor to type
and if I click the typing keys I cannot see any text that comes out on the screen.
thank you
« Reply #3 on: May 23, 2014, 01:04:14 pm »
If it's not even getting that far, I can only assume the optical drive is having problems reading the disk.
« Last Edit: May 23, 2014, 09:11:38 pm by PCNetSpec »
« Reply #4 on: May 23, 2014, 08:59:56 pm »
Thank You for your help
I appreciate it.
