Author Topic: Install will not run without USB in  (Read 4087 times)
AdrianT
  • Guest
« on: March 24, 2016, 10:55:59 am »
I'm struggling to install Peppermint 6 onto a machine. It has installed, but will not boot with nor even without the USB. However with Super Grub 2 on a USB I can get it to boot.
I've tried boot-repair but that did not help, I've tried all manner of solutions and grub updates etc. Any ideas? Thanks. I am no expert on Linux but with instruction can work in the terminal as I have Linux on another machine.
Re: Install will not run without USB in
« Reply #1 on: March 24, 2016, 11:05:18 am »
Hi AdrainT, and welcome to the forum :)
Boot Peppermint with your supergrub disk, then open a terminal and post the output from:
sudo fdisk -l
sudo blkid
AdrianT
  • Guest
« Reply #2 on: March 24, 2016, 11:26:58 am »
Thanks for the quick reply, much appreciated  :)
From what I can tell in my 15 to 20 hour mission already is that the USB is on sdb1, and that my primary hard drive is sda1.  I'm not certain if that helps you.
at@at-laptop ~ $ sudo fdisk -l
[sudo] password for at:
Disk /dev/sda: 100.0 GB, 100030242816 bytes
255 heads, 63 sectors/track, 12161 cylinders, total 195371568 sectors
Disk identifier: 0x00079c34
/dev/sda1   *        2048   191178751    95588352   83  Linux
/dev/sda2       191180798   195371007     2095105    5  Extended
/dev/sda5       191180800   195371007     2095104   82  Linux swap / Solaris
Disk /dev/sdb: 8100 MB, 8100249600 bytes
12 heads, 40 sectors/track, 32960 cylinders, total 15820800 sectors
Disk identifier: 0xc3072e18
/dev/sdb1   *        5992    15820799     7907404    c  W95 FAT32 (LBA)
at@at-laptop ~ $ sudo blkid
/dev/sda1: UUID="ac5b29ce-185b-422a-a9f2-dfcf5023f270" TYPE="ext4"
/dev/sda5: UUID="c9fb0343-fbc6-459b-af63-838831484492" TYPE="swap"
/dev/sdb1: LABEL="MULTIBOOT" UUID="15FF-1E15" TYPE="vfat"
at@at-laptop ~ $
« Last Edit: April 02, 2016, 04:17:41 am by AndyInMokum, Reason: Encapsulating output with [code] »
« Reply #3 on: March 24, 2016, 12:43:06 pm »
Boot using supergrub, then try running the 2 commands in sequence:
sudo grub-install /dev/sda
then:
sudo update-grub
then reboot without supergrub
AdrianT
  • Guest
« Reply #4 on: April 02, 2016, 03:08:51 am »
I tried that but no luck.
The screen sits on this for maybe 30 seconds:
And then it finally says this:
Sorry for the late reply - I was away for Easter.
« Reply #5 on: April 02, 2016, 04:15:14 am »
Hi Adrian
I could be way off the mark here but what I'm gonna suggest won't do any harm
it looks like your BIOS is set to boot from PXE, check your boot order in the BIOS and make sure the first boot drive is set to sda (or whatever the name of that drive is) or invoke the boot menu during boot and select the correct drive
Good luck
AdrianT
  • Guest
« Reply #6 on: April 03, 2016, 06:06:32 am »
Hi Graeme,
I did as as you suggested as shown below, but it came back to the same screen as above.
From my searches on the internet it seems that the installation loaded onto the USB itself, not the harddrive of the PC. Not the installation, but something. Sorry I am no expert at this.
At a stage I tried the suggestions in the link below, but am in hope that this forum shed some light:
http://askubuntu.com/questions/125494/cant-boot-without-flash-drive-plugged-in
My father passed away and I have an extra 3 spare laptops, two of them fairly old, and I want to give two of them away to someone who is more needy - and I thought giving them Windows to be a cruel punishment...
« Reply #7 on: April 03, 2016, 07:24:33 am »
Please post the output from:
sudo fdisk -l
sudo blkid
mount
and the contents of
gedit /etc/fstab
AdrianT
  • Guest
« Reply #8 on: April 03, 2016, 07:47:10 am »
at@at-laptop ~ $ mount
/dev/sda1 on / type ext4 (rw,errors=remount-ro)
proc on /proc type proc (rw,noexec,nosuid,nodev)
sysfs on /sys type sysfs (rw,noexec,nosuid,nodev)
none on /sys/fs/cgroup type tmpfs (rw)
none on /sys/fs/fuse/connections type fusectl (rw)
none on /sys/kernel/debug type debugfs (rw)
none on /sys/kernel/security type securityfs (rw)
udev on /dev type devtmpfs (rw,mode=0755)
devpts on /dev/pts type devpts (rw,noexec,nosuid,gid=5,mode=0620)
tmpfs on /run type tmpfs (rw,noexec,nosuid,size=10%,mode=0755)
none on /run/lock type tmpfs (rw,noexec,nosuid,nodev,size=5242880)
none on /run/shm type tmpfs (rw,nosuid,nodev)
none on /run/user type tmpfs (rw,noexec,nosuid,nodev,size=104857600,mode=0755)
none on /sys/fs/pstore type pstore (rw)
systemd on /sys/fs/cgroup/systemd type cgroup (rw,noexec,nosuid,nodev,none,name=systemd)
gvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,user=at)
at@at-laptop ~ $ gedit /etc/fstab
Then it opened a new window and displayed this:
# / was on /dev/sda1 during installation
UUID=ac5b29ce-185b-422a-a9f2-dfcf5023f270 /               ext4    errors=remount-ro 0       1
# swap was on /dev/sda5 during installation
UUID=c9fb0343-fbc6-459b-af63-838831484492 none            swap    sw              0       0
As a matter of interest, I just used the same USB to install Peppermint 6 to a Dell laptop as a dual with Windows XP and no problems.
« Reply #9 on: April 03, 2016, 08:03:43 am »
Okay, boot to the LiveUSB, open a terminal and run:
sudo mount /dev/sda1 /mnt
for i in /dev /dev/pts /proc /sys /run; do sudo mount -B $i /mnt$i; done
sudo chroot /mnt
update-grub
then hit Ctrl+D .. to exit the chroot environment.
Now shut down the PC, and see if it'll boot without the USB stick.
AdrianT
  • Guest
« Reply #10 on: April 03, 2016, 08:26:05 am »
Excuse the stupid question but you mean boot it up again using the USB with SuperGrub2 on it?
AdrianT
  • Guest
« Reply #11 on: April 03, 2016, 08:39:00 am »
I did try as you said, it said no errors. I shut down the laptop and removed the USB with SuperGrub2, started it up but some problem as shown a few posts before  :'(
« Reply #12 on: April 03, 2016, 09:47:14 am »
Erm, no .. with a Peppermint 6 LiveUSB
AdrianT
  • Guest
« Reply #13 on: April 04, 2016, 02:44:28 am »
Ok remember I cannot boot with that USB and open a terminal. So, I booted up with the SuperGrub2 USB, ejected it, placed in the LiveUSB with Peppermint 6 on and followed your instructions. Seems it has some kind of issue:
« Reply #14 on: April 04, 2016, 03:26:06 am »
Hi AdrianT,
With the computer turned off, insert the Peppermint Six USB stick and try doing what emegra recommended here. Only now select the USB stick.
