Author Topic: Wifi not connected  (Read 6108 times)
Offline unisus21
  • Peppermint version(s): P6
Re: Wifi not connected
« Reply #15 on: March 19, 2016, 05:26:05 am »
Thanks..what should I do next for spring my wifi to life
Sent from my LG-D838 using Tapatalk
« Reply #16 on: March 19, 2016, 03:46:35 pm »
run:
sudo modprobe -r b43 ssb wl brcmfmac brcmsmac bcmathen
sudo modprobe b43did wireless spring to life ?
if not, does:
dpkg -l | grep firmware-b43-installerreturn
ii  firmware-b43-installer
« Last Edit: March 19, 2016, 03:51:26 pm by PCNetSpec »
Offline unisus21
« Reply #17 on: March 19, 2016, 05:44:29 pm »
it goes like this
unisus21@unisus-Aspire-4715 ~ $ dpkg -l | grep firmware-b43-installer
ii  firmware-b43-installer                      1:018-2                                 all          firmware installer for the b43 driver
Offline unisus21
« Reply #18 on: March 19, 2016, 05:48:02 pm »
modprobe return like this
unisus21@unisus-Aspire-4715 ~ $ sudo modprobe -r b43 ssb wl brcmfmac brcmsmac bcma
[sudo] password for unisus21:
empty..which is mean that I dont have b43 install ?
« Reply #19 on: March 19, 2016, 07:21:10 pm »
modprobe commands don't return any output unless there's a problem .. so just run BOTH commands and tell me if wireless now works
ie. after running BOTH commands in the order given .. now if you click the networkmanager icon by the clock, is your network listed ?
Offline unisus21
« Reply #20 on: March 20, 2016, 02:07:23 am »
Yes it is listed but cannot connect into my wireless network..
Offline unisus21
« Reply #21 on: March 20, 2016, 02:31:08 am »
If all of this not working, should I go and buy wifi dongle instead?
« Reply #22 on: March 20, 2016, 03:11:55 am »
If your wireless network is listed and not greyed out, you'll be able to connect into it.  When you left click on your wireless network from the list.  You should be presented with a box asking for your password.  Similar to the image below:
 This is not your user password.  You must enter your WiFi password.  This is usually found on the back of the router your ISP gave you.  Enter this and click on connect.  That should connect you to the internet  ;).
Offline unisus21
« Reply #23 on: March 20, 2016, 04:33:27 am »
What you mean by not my password..I'm using my own router because my ISP router were broken few years now..and I cannot find password on the back of my latest router
Offline unisus21
« Reply #24 on: March 20, 2016, 04:56:55 am »
By the way..I'll already enter my wifi password (usually used,not from back of a router coz can't find it ) yet still not connected..
« Reply #25 on: March 20, 2016, 08:34:08 am »
Okay, what's the output from:
iwconfigand
iwlist scanand
rfkill listand does the box Andy showed you accept your wireless password, or tell you it's incorrect ?
What Andy meant by "this is not your password" is the dialogbox in his pic does NOT expect your Peppermint password, it expects your *wireless* password .. if you do not know your wireless password there is no way to connect.
At this point there's little point in getting a USB wireless card .. the Broadcom one *IS* supported .. firstly we need to figure out if the problem is
a) you don't know the wireless password, or have been entering it wrong
or
b) if the Broadcom adapter is physically broken, or there's a software issue somewhere
or
c) the Broadcom adapter is being blocked for some reason
Offline unisus21
« Reply #26 on: March 23, 2016, 02:51:55 am »
iwconfig
unisus21@unisus-Aspire-4715 ~ $ iwconfig
wlan0     IEEE 802.11abg  ESSID:off/any
          Mode:Managed  Access Point: Not-Associated
          Retry short limit:7   RTS thr:off   Fragment thr:off
          Power Management:off
eth0      no wireless extensions.
iwlist scan
unisus21@unisus-Aspire-4715 ~ $ iwlist scan
wlan0     Scan completed :
          Cell 01 - Address: 9C:D6:43:81:51:B6
                    Channel:1
                    Frequency:2.412 GHz (Channel 1)
                    Quality=70/70  Signal level=-37 dBm
                    Encryption key:on
                    ESSID:"UNISUS_wifi"
                    Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 6 Mb/s
                              9 Mb/s; 12 Mb/s; 18 Mb/s
                    Bit Rates:24 Mb/s; 36 Mb/s; 48 Mb/s; 54 Mb/s
                    Mode:Master
                    Extra:tsf=0000000000000000
                    Extra: Last beacon: 14024ms ago
                    IE: Unknown: 000B554E495355535F77696669
                    IE: Unknown: 010882848B960C121824
                    IE: Unknown: 030101
                    IE: Unknown: 2A0100
                    IE: Unknown: 32043048606C
                    IE: Unknown: DD180050F2020101000003A4000027A4000042435E0062322F00
                    IE: Unknown: DD7C0050F204104A0001101044000102103B00010310470010630412531019200612289CD6438151B610210006442D4C696E6B1023000752544C383637311024000D45562D323030362D30372D32371042000C3963643634333831353161641054000800060050F20400011011000944534C2D3237353045100800020086
                    IE: Unknown: DD050050F20500
                    IE: Unknown: DD0600E04C020160
eth0      Interface doesn't support scanning.
rfkill list
unisus21@unisus-Aspire-4715 ~ $ rfkill list
0: acer-wireless: Wireless LAN
Soft blocked: no
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
2: brcmwl-0: Wireless LAN
Soft blocked: no
Hard blocked: no
« Reply #27 on: March 23, 2016, 05:33:38 am »
Well I can see nothing wrong there
So can you answer my other question - "does the box Andy showed you accept your wireless password, or tell you it's incorrect ?"
You need to describe exactly what's happening when you try to connect.
Offline unisus21
« Reply #28 on: March 23, 2016, 07:06:30 am »
Yeah it accepted my wifi password..Then the icon kinda circling for sometime..then a box pop out addressed me "disconnected-you now offline"..same thing happen when I'm installed Mint and Ubuntu..not connected to wifi..when I'm on windows previously, it worked perfectly..driver that listed are Broadcom Linux sta something only..that normal right?
Offline Capivara
  • Devoted To Daemons & Penguins
  • Peppermint version(s): 6, 7
« Reply #29 on: March 23, 2016, 07:56:44 am »
I know that problem all too well, but here it's not Linux related. It's my modem/router (Siemens) in desperate need of a reset. I disconnect the power, wait 5 seconds, connect it again and I'm fine for a week or so.  This started to happen when more and more (wireless) devices started to populate the house. At a certain point in time the router started to develop this problem.
If you like Linux, raise your hand. If you don't, raise your standards.
