Author Topic: something has changed with Vimeo? [SOLVED]  (Read 7887 times)
Online spence
    • My MeWe profile
« on: May 21, 2014, 01:40:44 pm »
I'm having trouble getting sound on vimeo... Using Chromium, the video will play, but no sound comes thru... Using Midori or Seamonkey... the videos return error messages and won't play at all
« Last Edit: May 21, 2014, 04:47:16 pm by spence »
 '18 Asus VivoBook
Re: something has changed with Vimeo?
« Reply #1 on: May 21, 2014, 02:36:38 pm »
Working for me in Firefox.
Did we add the fixed gecko-media-player on your system ?
and have you got pulseaudio installed ?
Online spence
    • My MeWe profile
« Reply #2 on: May 21, 2014, 02:53:02 pm »
no and no...
 '18 Asus VivoBook
« Reply #3 on: May 21, 2014, 03:03:49 pm »
First thing to try would be to add pulseaudeio:
sudo apt-get install pulseaudio pulseaudio-utils pavucontrol
and see if that helps ?
{EDIT]
Are you sure we didn't update gecko-mediaplayer ?
http://peppermintos.net/viewtopic.php?f=35&t=6508&hilit=gecko&start=20
what's the output from:
dpkg -l | grep gecko-mediaplayer
« Last Edit: May 21, 2014, 03:11:19 pm by PCNetSpec »
Online spence
    • My MeWe profile
« Reply #4 on: May 21, 2014, 03:12:06 pm »
whilst pondering what we'd done previously with sound, i decided to  follow the directions in the post "What is it with Shockwave?" as a first step...
http://forum.peppermintos.com/index.php/topic,279.0.html and all is well with Chromium...
Seamonkey gives me an error saying "this plugin is vulnerable and should be updated while Midori still refuses to play..
EDIT ... after pausing the video long enough to post this reply... it no longer plays any sound in Chromium... but does work well in Seamonkey... Midori still nada
« Last Edit: May 23, 2014, 01:18:28 pm by spence »
 '18 Asus VivoBook
Online spence
    • My MeWe profile
« Reply #5 on: May 21, 2014, 03:21:29 pm »
guess my mind has gone blank about working with geck-mediaplayer previously... would pulse audio be in addition to guayadeque or just anothr layer of sound?
{EDIT]
ii  gecko-mediaplayer                     1.0.8-4ubuntu1                           amd64        Multimedia plug-in for Gecko browsers
 '18 Asus VivoBook
« Reply #6 on: May 21, 2014, 03:26:09 pm »
Well let's undo that
rm -v ~/.mozilla/plugins/libflashplayer.so
Now close ALL web browser instances and restart Chromium.  <-- this is important
In chromium, go to
chrome://plugins
and tell us which version of Shockwave Flash is listed as enabled.
Pulseaudio is NOT a media player .. it's a sound server.
Online spence
    • My MeWe profile
« Reply #7 on: May 21, 2014, 03:38:48 pm »
there is no specific listing for shockwave... however there is this:
mplayerplug-in is now gecko-mediaplayer 1.0.8
Gecko Media Player 1.0.8
Video Player Plug-in for QuickTime, RealPlayer and Windows Media Player streams using MPlayer
« Last Edit: May 21, 2014, 03:54:31 pm by spence »
 '18 Asus VivoBook
« Reply #8 on: May 21, 2014, 03:45:12 pm »
OK, can you post the output from:
dpkg -l | grep flash
and tell me if there is any output from:
cat /proc/cpuinfo | grep sse2
Can you also run:
sudo updatedb
then post the output (if any) from:
locate libpepflashplayer.so
« Last Edit: May 21, 2014, 03:50:27 pm by PCNetSpec »
Online spence
    • My MeWe profile
« Reply #9 on: May 21, 2014, 03:52:41 pm »
reopening this page i get a "Adobe Flash Player is required..." since the video is linked
no output
flags		: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp lm 3dnowext 3dnow constant_tsc rep_good nopl nonstop_tsc extd_apicid aperfmperf pni monitor cx16 popcnt lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw ibs skinit wdt arat cpb hw_pstate npt lbrv svm_lock nrip_save pausefilter
no output from locate libpepflashplayer.so
« Last Edit: May 21, 2014, 03:57:37 pm by spence »
 '18 Asus VivoBook
« Reply #10 on: May 21, 2014, 03:58:06 pm »
OK, run:
sudo apt-get install --reinstall flashplugin-installer
then close ALL web browser instances and reopen Chromium.
Does the above Vimeo video work now ?
Online spence
    • My MeWe profile
« Reply #11 on: May 21, 2014, 04:09:16 pm »
video and sound  both work in Chromium, video only works in Seamonkey, nothing works in Midori
« Last Edit: May 24, 2014, 06:25:29 pm by spence »
 '18 Asus VivoBook
« Reply #12 on: May 21, 2014, 04:15:30 pm »
I take it the volume bars are all light up in the vimeo video bar ?
and gecko-mediaplayer is enabled in Seamonkey ?
Online spence
    • My MeWe profile
« Reply #13 on: May 21, 2014, 04:23:32 pm »
yes all all bars light up in vimeo ... gecko-mediaplay 1.0.8 appears all over the place in helper applications... but not for SWF...
 '18 Asus VivoBook
« Reply #14 on: May 21, 2014, 04:39:10 pm »
so in Seamonkey if you go to
about:plugins
you don't see these
video/x-flv   Flash Video   flv
video/flv   Flash Video   flv
under the
