Author Topic: Update error - SOLVED  (Read 5175 times)
Re: Update error
« Reply #15 on: February 29, 2016, 05:31:12 pm »
No, it's to do with secureboot module (driver) signing.
Is this a UEFI system ? .. what's the output from:
[ -d /sys/firmware/efi ] && echo UEFI || echo BIOS
Offline Bigoeuf
Re: Update error
« Reply #16 on: February 29, 2016, 05:38:23 pm »
mick@mick-Inspiron-1501 ~ $ [ -d /sys/firmware/efi ] && echo UEFI || echo BIOS
BIOS
I was pretty sure it was but best to be certain  ;)
Offline Bigoeuf
Re: Update error
« Reply #17 on: March 01, 2016, 02:44:42 am »
BIOS
So inlight of these last two posts PCNetSpec would I be correct in believing this has no relevance for my system & as far as you can see the kernel updates were installed correctly?
Re: Update error
« Reply #18 on: March 01, 2016, 03:17:38 am »
You're right they have no relevance for your system, the modules referenced are obviously being loaded .. I think the best course of action would be to just wait and see if they disappear after the next kernel update.
The other option might be to move to the 3.19 kernel series now .. but I don't think it's necessary.
Piece of advice though .. if you ever start an update, LET IT FINISH even if you spot something you don't like .. far better to remove what you don't like after successful installation than to risk screwing up your system with half installed system files ;)
Offline Bigoeuf
Re: Update error
« Reply #19 on: March 01, 2016, 04:05:33 am »
Absolutely PCNetSpec - that's what I was flapping about. I know you say moving to 3.19 isn't necessary but it would be nice to "clean up" the kernel - three questions if I may:
1. Would it work on my laptop?
  Specs:
System:    Host: mick-Inspiron-1501 Kernel: 3.16.0-62-generic i686 (32 bit) Desktop: N/A Distro: Peppermint Six
Machine:   System: Dell product: Inspiron 1501
           Mobo: Dell model: 0UW744 Bios: Dell version: 1.7.0 date: 11/24/2006
CPU:       Single core AMD Turion 64 Mobile MK-36 (-UP-) cache: 512 KB flags: (lm nx pae sse sse2 sse3 svm) clocked at 2000.00 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] RS482M [Mobility Radeon Xpress 200]
           X.Org: 1.16.0 drivers: ati,radeon (unloaded: fbdev,vesa) Resolution: 1280x800@61.0hz
           GLX Renderer: Gallium 0.4 on ATI RS480 GLX Version: 2.1 Mesa 10.3.2
Audio:     Card: Advanced Micro Devices [AMD/ATI] SBx00 Azalia (Intel HDA) driver: snd_hda_intel
           Sound: Advanced Linux Sound Architecture ver: k3.16.0-62-generic
Network:   Card-1: Broadcom BCM4401-B0 100Base-TX driver: b44
           IF: eth0 state: down mac: <filter>
           Card-2: Broadcom BCM4311 802.11b/g WLAN driver: b43-pci-bridge
           IF: wlan0 state: up mac: <filter>
Drives:    HDD Total Size: 60.0GB (11.7% used) 1: id: /dev/sda model: SAMSUNG_HM060HI size: 60.0GB
Partition: ID: / size: 9.1G used: 6.6G (77%) fs: ext4 ID: swap-1 size: 2.00GB used: 0.00GB (0%) fs: swap
Sensors:   System Temperatures: cpu: 60.0C mobo: N/A
Info:      Processes: 146 Uptime: 6 min Memory: 448.2/1890.1MB Client: Shell (bash) inxi: 1.9.17
2. Is it stable? (specifically for my system)
3. If so what's the best way to install it?
I've just had a look through my  /var/log/syslog specifically for my latest boot & I cant see any errors (to my untutored eyes anyway) - would it help to post it? I wouldn't be insecure doing so would I?
Regards
« Last Edit: September 15, 2016, 04:43:37 am by Bigouef »
Re: Update error
« Reply #20 on: March 01, 2016, 06:08:55 am »
In fact we'll be moving you to the even more recent 4.2 kernel via the LTS enablement stack (as it's recently been updated).
1) I can see no reason why it wouldn't
2) Yes it's stable .. it's the kernel used in Ubuntu 14.04.4 and 15.10
3) (For anyone else reading this, these instructions are for 32bit Peppermint 6 ONLY) Open a terminal and run:
sudo apt-get install --install-recommends linux-generic-lts-wily xserver-xorg-core-lts-wily xserver-xorg-lts-wily xserver-xorg-video-all-lts-wily xserver-xorg-input-all-lts-wily libwayland-egl1-mesa-lts-wilyonce that's finished...
REBOOT (it's important that you reboot)
Now post the output from:
uname -aand
dpkg -l | grep 3.16.0and
dpkg -l | grep lts-utopic
Offline Bigoeuf
Re: Update error
« Reply #21 on: March 01, 2016, 07:59:21 am »
Hello PCNetSpec - I've done as you suggested & implemented the 4.2 kernel install via your command rebooted & here are the outputs you requested:
mick@mick-Inspiron-1501 ~ $ uname -a
Linux mick-Inspiron-1501 4.2.0-30-generic #36~14.04.1-Ubuntu SMP Fri Feb 26 18:50:14 UTC 2016 i686 athlon i686 GNU/Linux
mick@mick-Inspiron-1501 ~ $ dpkg -l | grep 3.16.0
ii  linux-generic-lts-utopic                   3.16.0.62.53                            i386         Complete Generic Linux kernel and headers
ii  linux-headers-3.16.0-46                    3.16.0-46.62~14.04.1                    all          Header files related to Linux kernel version 3.16.0
ii  linux-headers-3.16.0-46-generic            3.16.0-46.62~14.04.1                    i386         Linux kernel headers for version 3.16.0 on 32 bit x86 SMP
ii  linux-headers-3.16.0-60                    3.16.0-60.80~14.04.1                    all          Header files related to Linux kernel version 3.16.0
ii  linux-headers-3.16.0-60-generic            3.16.0-60.80~14.04.1                    i386         Linux kernel headers for version 3.16.0 on 32 bit x86 SMP
ii  linux-headers-3.16.0-62                    3.16.0-62.83~14.04.1                    all          Header files related to Linux kernel version 3.16.0
ii  linux-headers-3.16.0-62-generic            3.16.0-62.83~14.04.1                    i386         Linux kernel headers for version 3.16.0 on 32 bit x86 SMP
ii  linux-headers-generic-lts-utopic           3.16.0.62.53                            i386         Generic Linux kernel headers
rc  linux-image-3.16.0-37-generic              3.16.0-37.51~14.04.1                    i386         Linux kernel image for version 3.16.0 on 32 bit x86 SMP
ii  linux-image-3.16.0-46-generic              3.16.0-46.62~14.04.1                    i386         Linux kernel image for version 3.16.0 on 32 bit x86 SMP
ii  linux-image-3.16.0-60-generic              3.16.0-60.80~14.04.1                    i386         Linux kernel image for version 3.16.0 on 32 bit x86 SMP
ii  linux-image-3.16.0-62-generic              3.16.0-62.83~14.04.1                    i386         Linux kernel image for version 3.16.0 on 32 bit x86 SMP
rc  linux-image-extra-3.16.0-37-generic        3.16.0-37.51~14.04.1                    i386         Linux kernel extra modules for version 3.16.0 on 32 bit x86 SMP
ii  linux-image-extra-3.16.0-46-generic        3.16.0-46.62~14.04.1                    i386         Linux kernel extra modules for version 3.16.0 on 32 bit x86 SMP
ii  linux-image-extra-3.16.0-60-generic        3.16.0-60.80~14.04.1                    i386         Linux kernel extra modules for version 3.16.0 on 32 bit x86 SMP
ii  linux-image-extra-3.16.0-62-generic        3.16.0-62.83~14.04.1                    i386         Linux kernel extra modules for version 3.16.0 on 32 bit x86 SMP
ii  linux-image-generic-lts-utopic             3.16.0.62.53                            i386         Generic Linux kernel image
mick@mick-Inspiron-1501 ~ $ dpkg -l | grep lts-utopic
rc  libegl1-mesa-lts-utopic:i386               10.3.2-0ubuntu1~trusty2                 i386         free implementation of the EGL API -- runtime
rc  libgbm1-lts-utopic:i386                    10.3.2-0ubuntu1~trusty2                 i386         generic buffer management API -- runtime
rc  libgl1-mesa-dri-lts-utopic:i386            10.3.2-0ubuntu1~trusty2                 i386         free implementation of the OpenGL API -- DRI modules
rc  libgl1-mesa-glx-lts-utopic:i386            10.3.2-0ubuntu1~trusty2                 i386         free implementation of the OpenGL API -- GLX runtime
rc  libglapi-mesa-lts-utopic:i386              10.3.2-0ubuntu1~trusty2                 i386         free implementation of the GL API -- shared library
rc  libgles1-mesa-lts-utopic:i386              10.3.2-0ubuntu1~trusty2                 i386         free implementation of the OpenGL|ES 1.x API -- runtime
rc  libgles2-mesa-lts-utopic:i386              10.3.2-0ubuntu1~trusty2                 i386         free implementation of the OpenGL|ES 2.x API -- runtime
rc  libopenvg1-mesa-lts-utopic:i386            10.3.2-0ubuntu1~trusty2                 i386         free implementation of the OpenVG API -- runtime
rc  libwayland-egl1-mesa-lts-utopic:i386       10.3.2-0ubuntu1~trusty2                 i386         implementation of the Wayland EGL platform -- runtime
rc  libxatracker2-lts-utopic:i386              10.3.2-0ubuntu1~trusty2                 i386         X acceleration library -- runtime
rc  xserver-xorg-core-lts-utopic               2:1.16.0-1ubuntu1.2~trusty2             i386         Xorg X server - core server
rc  xserver-xorg-lts-utopic                    1:7.7+7ubuntu2~trusty1                  i386         X.Org X server
rc  xserver-xorg-video-intel-lts-utopic        2:2.99.914-1~exp1ubuntu4.5~trusty1      i386         X.Org X server -- Intel i8xx, i9xx display driver
rc  xserver-xorg-video-modesetting-lts-utopic  0.9.0-1build1~trusty1                   i386         X.Org X server -- Generic modesetting driver
rc  xserver-xorg-video-openchrome-lts-utopic   1:0.3.3-1build2~trusty1                 i386         X.Org X server -- VIA display driver
rc  xserver-xorg-video-vmware-lts-utopic       1:13.0.2-3ubuntu1~trusty1               i386         X.Org X server -- VMware display driver
Re: Update error
« Reply #22 on: March 01, 2016, 08:14:51 am »
Okay, if you want to remove all the old kernels and redundant xorg stuff, run BOTH of these commands in sequence:
sudo apt-get remove --purge linux-generic-lts-utopic linux-headers-3.16.0-46 linux-headers-3.16.0-46-generic linux-headers-3.16.0-60 linux-headers-3.16.0-60-generic linux-headers-3.16.0-62 linux-headers-3.16.0-62-generic linux-headers-generic-lts-utopic linux-image-3.16.0-37-generic linux-image-3.16.0-46-generic linux-image-3.16.0-60-generic linux-image-3.16.0-62-generic linux-image-extra-3.16.0-37-generic linux-image-extra-3.16.0-46-generic linux-image-extra-3.16.0-60-generic linux-image-extra-3.16.0-62-generic linux-image-generic-lts-utopic libegl1-mesa-lts-utopic:i386 libgbm1-lts-utopic:i386 libgl1-mesa-dri-lts-utopic:i386 libgl1-mesa-glx-lts-utopic:i386 libglapi-mesa-lts-utopic:i386 libgles1-mesa-lts-utopic:i386 libgles2-mesa-lts-utopic:i386 libopenvg1-mesa-lts-utopic:i386 libwayland-egl1-mesa-lts-utopic:i386 libxatracker2-lts-utopic:i386 linux-generic-lts-utopic linux-headers-generic-lts-utopic linux-image-generic-lts-utopic xserver-xorg-core-lts-utopic xserver-xorg-lts-utopic xserver-xorg-video-intel-lts-utopic xserver-xorg-video-modesetting-lts-utopic xserver-xorg-video-openchrome-lts-utopic xserver-xorg-video-vmware-lts-utopicthen make SURE to run this command BEFORE rebooting:
sudo apt-get install --reinstall xserver-xorg-core-lts-wily xserver-xorg-lts-wily xserver-xorg-video-intel-lts-wily xserver-xorg-video-modesetting-lts-wily xserver-xorg-video-openchrome-lts-wily xserver-xorg-video-vmware-lts-wily
Offline Bigoeuf
Re: Update error
« Reply #23 on: March 01, 2016, 02:15:45 pm »
Hello again PCNetSpec. I ran both commands but this i what came back on the second one:
mick@mick-Inspiron-1501 ~ $ sudo apt-get install --reinstall xserver-xorg-core-lts-wily xserver-xorg-lts-wily xserver-xorg-video-intel-lts-wily xserver-xorg-video-modesetting-lts-wily xserver-xorg-video-openchrome-lts-wily xserver-xorg-video-vmware-lts-wily
Reading package lists... Done
Building dependency tree
E: Unable to locate package xserver-xorg-video-modesetting-lts-wily
I havent rebooted yet
Cheers
Re: Update error
« Reply #24 on: March 01, 2016, 02:40:50 pm »
okay, leave that one out:
sudo apt-get install --reinstall xserver-xorg-core-lts-wily xserver-xorg-lts-wily xserver-xorg-video-intel-lts-wily xserver-xorg-video-openchrome-lts-wily xserver-xorg-video-vmware-lts-wily
Offline Bigoeuf
Re: Update error
« Reply #25 on: March 01, 2016, 03:33:39 pm »
OK done that & reported back this:
mick@mick-Inspiron-1501 ~ $ sudo apt-get install --reinstall xserver-xorg-core-lts-wily xserver-xorg-lts-wily xserver-xorg-video-intel-lts-wily xserver-xorg-video-openchrome-lts-wily xserver-xorg-video-vmware-lts-wily
[sudo] password for mick:
The following package was automatically installed and is no longer required:
  libllvm3.5
Use 'apt-get autoremove' to remove it.
0 to upgrade, 0 to newly install, 5 reinstalled, 0 to remove and 2 not to upgrade.
Need to get 0 B/2,146 kB of archives.
After this operation, 0 B of additional disk space will be used.
(Reading database ... 157604 files and directories currently installed.)
Preparing to unpack .../xserver-xorg-core-lts-wily_2%3a1.17.2-1ubuntu9.1~trusty1_i386.deb ...
Unpacking xserver-xorg-core-lts-wily (2:1.17.2-1ubuntu9.1~trusty1) over (2:1.17.2-1ubuntu9.1~trusty1) ...
Preparing to unpack .../xserver-xorg-lts-wily_1%3a7.7+7ubuntu4~trusty1_i386.deb ...
Unpacking xserver-xorg-lts-wily (1:7.7+7ubuntu4~trusty1) over (1:7.7+7ubuntu4~trusty1) ...
Preparing to unpack .../xserver-xorg-video-intel-lts-wily_2%3a2.99.917+git20150808-0ubuntu4~trusty2_i386.deb ...
Unpacking xserver-xorg-video-intel-lts-wily (2:2.99.917+git20150808-0ubuntu4~trusty2) over (2:2.99.917+git20150808-0ubuntu4~trusty2) ...
Preparing to unpack .../xserver-xorg-video-openchrome-lts-wily_1%3a0.3.3-1ubuntu1~trusty1_i386.deb ...
Unpacking xserver-xorg-video-openchrome-lts-wily (1:0.3.3-1ubuntu1~trusty1) over (1:0.3.3-1ubuntu1~trusty1) ...
Preparing to unpack .../xserver-xorg-video-vmware-lts-wily_1%3a13.1.0-0ubuntu1build2~trusty1_i386.deb ...
Unpacking xserver-xorg-video-vmware-lts-wily (1:13.1.0-0ubuntu1build2~trusty1) over (1:13.1.0-0ubuntu1build2~trusty1) ...
Processing triggers for man-db (2.6.7.1-1ubuntu1) ...
Setting up xserver-xorg-core-lts-wily (2:1.17.2-1ubuntu9.1~trusty1) ...
Setting up xserver-xorg-lts-wily (1:7.7+7ubuntu4~trusty1) ...
Setting up xserver-xorg-video-intel-lts-wily (2:2.99.917+git20150808-0ubuntu4~trusty2) ...
Setting up xserver-xorg-video-openchrome-lts-wily (1:0.3.3-1ubuntu1~trusty1) ...
Setting up xserver-xorg-video-vmware-lts-wily (1:13.1.0-0ubuntu1build2~trusty1) ...
Processing triggers for libc-bin (2.19-0ubuntu6.7) ...
I presume I should do:
......The following package was automatically installed and is no longer required:
  libllvm3.5
Use 'apt-get autoremove' to remove it......
PCNetSpec?
Again I haven't rebooted yet
Re: Update error
« Reply #26 on: March 01, 2016, 06:20:24 pm »
Yeah you can do that if you want, but you should be okay to reboot now anyway.
Offline Bigoeuf
Re: Update error
« Reply #27 on: March 02, 2016, 12:46:08 am »
Cheers PCNetSpec I've done that (removing libllvm3.5 freed up a few MB). Well I wasn't expecting this when I first posted & now you've put me on the "frontier" of Peppermint 6 OS  ;D  Anyway lesson learnt for me  {Re your advice in reply #18).
Should I notice much difference with this kernel? though I appreciate its the latest & shall I mark the topic SOLVED?  :)
Re: Update error
« Reply #28 on: March 02, 2016, 04:54:54 am »
You're welcome...
You probably won't notice much difference besides some added hardware support (*some* people have commented that '4' series kernels are a bit quicker on their systems .. but I can't say I've noticed a difference).
You can mark the topic solved if those "Request for unknown module key 'Magrathea: Glacier signing key: b996477e561b87c7074b21dd262f4ff201675ce7' err -11" messages have stopped in /var/log/syslog .. but in reality they're unimportant on a legacy BIOS system anyway (so I'll leave that up to you) ;)
Offline Bigoeuf
Re: Update error
« Reply #29 on: March 02, 2016, 05:27:39 am »
Well after using my upgraded OS for about a day it feels a little snappier (i.e things seam to load a little quicker - Desktop Icons, application opening).
Have checked the last 2 syslog's in /var/log/ & no sign of  "Request for unknown module key 'Magrathea: Glacier signing key: b996477e561b87c7074b21dd262f4ff201675ce7' err -11" so that is good & I will mark the topic SOLVED.
So PCNetSpec just remains for me to thank you once again  :) This is a smashing OS & a friendly & helpful community forum - if i could just get my battery to charge on the old Inspiron I would be in Dickie's Meadow  :D
