Author Topic: Windows 10 will keep spying on you no matter how hard you try to stop it  (Read 5309 times)
Hi
I am pretty sure the last time I tried that app it also stopped updates ???
Maybe it was how I set it up, but because of that I will never use it again and suggest other people stay away from it, especially computer illiterate friends and family. They WILL tinker - lol
The PoorGuy
  • Guest
« Last Edit: August 27, 2018, 06:06:06 pm by The PoorGuy »
The best way to update is sudo apt-get upgrade, or sudo apt-get dist-upgrade.  Not much to misunderstand.  8)
Yeah, you can't get much simpler than that.  I no longer feel comfortable running Windows.
The PoorGuy
  • Guest
« Last Edit: August 27, 2018, 06:05:48 pm by The PoorGuy »
The PoorGuy
  • Guest
« Last Edit: August 27, 2018, 06:05:31 pm by The PoorGuy »
