Author Topic: Dual or triple booting Linux distros  (Read 4004 times)
« on: February 07, 2016, 10:43:56 am »
Hi all, I want to double, possibly triple boot Peppermint Six with Xubuntu 15.10 and maybe Solus.  I can't remember where to put the boot loader on the additional distros.  I want to keep the Peppermint GRUB screen - many thanks  ;)
Offline Capivara
  • Devoted To Daemons & Penguins
  • Peppermint version(s): 6, 7
Re: Dual or triple booting Linux distros
« Reply #1 on: February 07, 2016, 10:55:49 am »
Uhhhmmm...
Last time I did that I used the Gparted Live CD to create 3 partitions on a hard drive. After that I installed the 3 distros, assigning each to another partition. The last distro is the 'winner' when it comes to GRUB. Zo, install Peppermint last.
If this is incorrect (it has been a while), I'm sure someone will correct me.
Hans
If you like Linux, raise your hand. If you don't, raise your standards.
Offline aagimob
  • aagimob
  • Peppermint version(s): Peppermint 5 & Peppermint 10
« Reply #2 on: February 07, 2016, 11:35:40 am »
...hello Andy...if i remember correctly, you are Windows user, so do not forget to install  Windows FIRST...the rest will be easier... ;)
« Reply #3 on: February 07, 2016, 11:43:43 am »
Hi AndyInMokum,
Unfortunately, Capivara is right -- but only when you tell each distro to install GRUB in the MBR !!
Howerever, when you install the GRUB for each of the new Linux distros in the same partition as the new distro, then (if the GRUB from Peppermint Six is in the MBR) the Peppermint Six GRUB will remain untouched.  ;)
« Last Edit: February 07, 2016, 11:47:45 am by Slim.Fatz »
« Reply #4 on: February 07, 2016, 01:13:22 pm »
Thanks guys, I had a sneaky feeling I was going about this bassackwards  :).  I already have Peppermint Six installed and for all intents and purposes, it's finished.  I'd prefer to leave it that way.  If I continue with the installation of the other two distros.  Is there a way I can reinstall the Peppermint's GRUB to the MBR  :-\
Hi aagimob,  I haven't used Windows in years.  This new machine had a fresh Windows 7 installation.  This included an installation DVD and a genuine license key.  That installation lasted about 5 minutes.  When Windows told me not to turn off my machine because it was downloading updates - updates I hadn't asked for, viewed, or approved  >:(.  I honestly felt violated, so the plug was pulled and the partition was nuked without a second thought.  The wife is very happy with her new Windows 7 installation DVD though :D!!
« Reply #5 on: February 07, 2016, 01:30:29 pm »
Hi AndyInMokum,
Read my reply (above). If Peppermint Six was the first installation and its GRUB is in the MBR -- NO PROBLEMO !!
Just add the new installations to their own partitions, but when the installer asks where you should install GRUB, you put it in the partition of the new installation (e.g. in /dev/sda5). That way, the GRUB from Peppermint Six (in the MBR) will not be changed or touched in any way.
Then when finished reboot into Peppermint Six and in a terminal run:
sudo update-grub
That should work without any further action on your part. If not, ask back here again, partner.  8)
« Reply #6 on: February 07, 2016, 01:42:23 pm »
Cheers Slim, I'm a little slow on the uptake today.  It was the: sudo update-grub I was forgetting.  Of course, it'll pickup the other installations and add them to GRUB menu - thanks mate  ;).
« Reply #7 on: February 07, 2016, 01:58:09 pm »
My pleasure, Andy !!  :)
« Reply #8 on: February 07, 2016, 08:51:28 pm »
One distro goes on the MBR <-- This is the one that controls GRUB, call it the GRUB master distro if you will
(eg. /dev/sda)
All other distros you install GRUB to their partition
(eg. /dev/sda6)
you then boot the master distro, and run:
sudo update-grub
The above is for BIOS systems only .. it's different for UEFI
« Last Edit: February 07, 2016, 08:53:39 pm by PCNetSpec »
« Reply #9 on: February 08, 2016, 12:45:14 am »
(eg. /dev/sda)
(eg. /dev/sda6)
sudo update-grub
Cheers Mark, I'm not using Windows so I've installed everything using Legacy mode.  There's less gymnastics involved.  Everything is working great  ;).
« Reply #10 on: February 08, 2016, 07:21:22 am »
No worries Andy, I figured you already had the answer I just thought I'd lay it out for future searchers.
« Reply #11 on: May 21, 2018, 05:26:08 pm »
This future searcher thanks you... from the past now...
Triple Boot conquered today... peppermint 8 Respin / Lubuntu / Win10 1803 weee haaaa
Captain Janeway "All this time travel stuff, I swore I'd never do, the past is the future the future is the past... It all just gives me a headache
« Last Edit: May 25, 2018, 05:04:15 pm by spence »
« Reply #12 on: May 24, 2018, 07:30:24 am »
I wish I would have read this post a year or two ago. I always hated getting the grub of a distro I was checking out as the "master grub", especially Eclectica(?).
« Reply #13 on: May 24, 2018, 08:11:49 am »
Glad to have reminded you of it then alynur was always a mystery to me, and part of why I have never distro-hopped before. Other than the fact Peppermint is so perfect, there's little need to bother thanks to PCNetSpec !?!
« Reply #14 on: May 25, 2018, 11:05:21 am »
Bored today, so wiped my extended partition, set up a raft of new logical partitions and swap... managed to create a nice sized /home partition...  and now good to go once again... installing my distros and reminding myself to install peppermint8 Respin last in line... wheeeee
   8)
« Last Edit: May 25, 2018, 05:01:59 pm by spence »
