Author Topic: Path of .bashrc file in Peppermint 6 and How to add alias into it-SOLVED  (Read 1477 times)
Offline rajeev2631007
Hi,
I want to know what is the  path of .bashrc file in Peppermint 6 and How to add alias in it.
Rajeev Gautam
« Last Edit: February 02, 2016, 11:14:01 pm by rajeev2631007 »
Re: Path of .bashrc file in Peppermint 6 and How to add alias into it
« Reply #1 on: January 27, 2016, 03:23:27 am »
Hi,
Rajeev Gautam
The path you're looking for is:
~/.bashrc
to open it, enter:
gedit ~/.bashrc
The following link will help you with creating aliases in .bashrc: how-do-i-create-a-permanent-bash-alias  ;).
« Reply #2 on: January 27, 2016, 06:48:42 am »
Hi rajeev2631007,
As an example of an alias to check for updates and upgrade your system from a terminal, use this alias:
alias checkupdates='sudo apt-get update && sudo apt-get upgrade'
in your .bashrc file. After making the changes and saving them, open a terminal and run
alias
to see your aliases and to activate the newest one.
Basically an alias looks like this:
alias name-of-alias='what-to-run-with-the-alias'
No spaces around the = sign and single quotes around what-to-run-with-the-alias.
Re: Path of .bashrc file in Peppermint 6 and How to add alias into it --SOLVED
« Reply #3 on: February 02, 2016, 01:57:09 am »
Thanks you Slim.Fatz and Andy for you help.
I also found one tutorial for alias I hope it will be useful for other.
regards,
Rajeev Gautam
