Author Topic: Update Error -SOLVED  (Read 1004 times)
Offline jlschwartz
  • Forum User
« on: January 25, 2016, 02:00:42 pm »
My system had update to install but I got the following error:
E: /var/cache/apt/archives/guvcview_2.0.3+ubuntu2~ppa1+1334-0ubuntu1~201601250929~ubuntu14.04.1_amd64.deb: trying to overwrite '/usr/share/locale/bs/LC_MESSAGES/gview_v4l2core.mo', which is also in package guvcview-i18n 2.0.0+ubuntu2~trusty~ppa1
It apparently has something to do with guvcview but I'm not sure how to correct the error.  Please let me know what I should do.  Thanks.  :-\
« Last Edit: January 25, 2016, 06:36:13 pm by AndyInMokum, Reason: Encapsulating output with [code] »
Online PCNetSpec
Re: Update Error
« Reply #1 on: January 25, 2016, 02:18:12 pm »
Try:
sudo apt-get remove --purge guvcview guvcview-i18n libguvcview*
sudo apt-get install guvcview
« Last Edit: January 25, 2016, 02:21:32 pm by PCNetSpec »
Offline jlschwartz
  • Forum User
Re: Update Error -SOLVED
« Reply #2 on: January 25, 2016, 04:46:08 pm »
That fixed it.  Thanks so much.   ;D
