Author Topic: Toshiba Satellite A55 Sound  (Read 3271 times)
Offline greg selden
  • Peppermint version(s): four
« on: May 16, 2014, 07:37:56 pm »
I have no sound. Please HELP, I do not want to return to the dark side.
Peppermint Four
ALSA Mixer displays following information.
Card: Intel ICH6
Chip: SigmaTel STAC 9750,51
The PMC
       Out
       Path
       Mute
column indicates that the Mute is active, and will not toggle. The botton half of the "mute" is cut off by the window's boarder. The speaker button on the bottom bar of the home screen will toggle on and off.
System:    Host: greg-Satellite-A55 Kernel: 3.8.0-35-generic i686 (32 bit) Desktop: N/A Distro: Peppermint Four
Machine:   System: TOSHIBA product: Satellite A55 version: PSA5SU-09F00D
           Mobo: TOSHIBA model: Portable PC version: Version A0 Bios: TOSHIBA version: Version 1.00 date: 09/28/2005
CPU:       Single core Intel Celeron M (-UP-) cache: 1024 KB flags: (nx sse sse2) clocked at 1595.938 MHz
Graphics:  Card: Intel Mobile 915GM/GMS/910GML Express Graphics Controller
           X.Org: 1.13.3 drivers: intel (unloaded: fbdev,vesa) Resolution: 1024x768@60.0hz
           GLX Renderer: Mesa DRI Intel 915GM x86/MMX/SSE2 GLX Version: 1.4 Mesa 9.1.7
Audio:     Card: Intel 82801FB/FBM/FR/FW/FRW (ICH6 Family) AC'97 Audio Controller driver: snd_intel8x0
           Sound: Advanced Linux Sound Architecture ver: k3.8.0-35-generic
Network:   Card-1: Atheros AR2413/AR2414 Wireless Network Adapter [AR5005G(S) 802.11bg] driver: ath5k
           IF: wlan0 state: up mac: 00:11:f5:aa:9b:34
           Card-2: Intel 82562ET/EZ/GT/GZ - PRO/100 VE (LOM) Ethernet Controller Mobile driver: e100
           IF: eth0 state: down mac: 00:0e:7b:19:05:a0
Drives:    HDD Total Size: 40.0GB (6.4% used) 1: id: /dev/sda model: TOSHIBA_MK4026GA size: 40.0GB
Partition: ID: / size: 37G used: 2.4G (7%) fs: ext4 ID: swap-1 size: 0.53GB used: 0.20GB (37%) fs: swap
Sensors:   System Temperatures: cpu: 33.0C mobo: N/A
Info:      Processes: 137 Uptime: 33 min Memory: 329.4/487.9MB Client: Shell inxi: 1.8.4
Offline mac
Re: Toshiba Satellite A55 Sound
« Reply #1 on: May 16, 2014, 07:47:02 pm »
Open your terminal and run...
sudo apt-get update && sudo apt-get install pulseaudio pulseaudio-utils pavucontrol
Reboot and test your sound.
Reg. Linux User #432835
« Reply #2 on: May 16, 2014, 08:03:37 pm »
Once the OP responds, I'm going to move this to the "Support > Hardware" forum.
I'll also send a link to the new location to the OP.
This forum is not for support questions ;)
Offline greg selden
« Reply #3 on: May 18, 2014, 05:25:42 pm »
I ran the command line and restarted, Still no sound through the speakers, or headphones.
« Reply #4 on: May 18, 2014, 05:54:59 pm »
Run this command (it's all one command, so probably best to copy/paste):
wget -O alsa-info.sh http://www.alsa-project.org/alsa-info.sh && chmod +x ./alsa-info.sh && ./alsa-info.sh
hit enter when presented with "OK"
Hit the tab key to select "UPLOAD/SHARE"
Hit enter
hit enter to accept "YES"
ht enter to accept "EXIT"
there will now be a URL (web link) in your terminal .. similar to:-
http://www.alsa-project.org/db/?f=e642840588b26b53b24dd1ebfa7244346cbcb726
can you post that link here.
