Author Topic: Trying to install Guitar Pro 6 for Linux  (Read 23033 times)
Offline globetrotterdk
  • Peppermint version(s): Peppermint OS 7 64-bit
« on: May 14, 2014, 08:57:50 am »
I seem to remember that it is possible to install 32-bit libs on a 64-bit system...
First I tried the following:
$ sudo dpkg -i gp6-full-linux-r11621.deb
Selecting previously unselected package guitarpro6.
(Reading database ... 262363 files and directories currently installed.)
Unpacking guitarpro6 (from gp6-full-linux-r11621.deb) ...
dpkg: dependency problems prevent configuration of guitarpro6:
guitarpro6 depends on gksu.
guitarpro6 depends on libasound2.
guitarpro6 depends on libc6 (>= 2.1.3).
guitarpro6 depends on libglu1-mesa.
guitarpro6 depends on libportaudio0.
guitarpro6 depends on libportaudio2.
guitarpro6 depends on libssl0.9.8.
guitarpro6 depends on libstdc++6.
guitarpro6 depends on libxml2.
guitarpro6 depends on libxslt1.1.
guitarpro6 depends on zlib1g.
dpkg: error processing guitarpro6 (--install):
dependency problems - leaving unconfigured
Processing triggers for desktop-file-utils ...
guitarpro6
Next, I tried this:
$ sudo apt-get install gksu libasound2 libc6 libglu1-mesa libportaudio0 libportaudio2 libssl0.9.8 libstdc++6 libxml2 libxslt1.1 zlib1g
Reading package lists... Done
Building dependency tree
gksu is already the newest version.
libglu1-mesa is already the newest version.
libglu1-mesa set to manually installed.
libportaudio2 is already the newest version.
libstdc++6 is already the newest version.
libxslt1.1 is already the newest version.
zlib1g is already the newest version.
libasound2 is already the newest version.
libasound2 set to manually installed.
libc6 is already the newest version.
libxml2 is already the newest version.
You might want to run 'apt-get -f install' to correct these:
The following packages have unmet dependencies:
guitarpro6:i386 : Depends: gksu:i386 but it is not going to be installed
Depends: libasound2:i386 but it is not going to be installed
Depends: libc6:i386 (>= 2.1.3) but it is not going to be installed
Depends: libglu1-mesa:i386 but it is not going to be installed
Depends: libportaudio0:i386 but it is not going to be installed
Depends: libportaudio2:i386 but it is not going to be installed
Depends: libssl0.9.8:i386 but it is not going to be installed
Depends: libstdc++6:i386 but it is not going to be installed
Depends: libxml2:i386 but it is not going to be installed
Depends: libxslt1.1:i386 but it is not going to be installed
Depends: zlib1g:i386 but it is not going to be installed
Then I received the following reply from Guitar Pro support:
Thank you for contacting the Arobas Music support.
I am sorry but Guitar Pro 6 is not supported with Linux 64 bit, only Ubuntu 32 bit.
Can I install these libs as 32-bit versions on my 64-bit system? I am also concerned they insist on installing gksu as it seems to remove sudo, which I am not too thrilled about to put it mildly...
Any ideas?
« Last Edit: May 25, 2014, 07:36:30 am by globetrotterdk »
Offline mac
Re: Trying to install Guitar Pro 6 for Linux
« Reply #1 on: May 14, 2014, 09:28:36 am »
hi globetrotterdk
to install 32bit libs....
sudo apt-get install ia32-libs-multiarch
gksu is already installed by default
Reg. Linux User #432835
« Reply #2 on: May 14, 2014, 12:07:48 pm »
Many thanks. That solved most of the problem:
(Reading database ... 263980 files and directories currently installed.)
 guitarpro6
I then tried the following:
$ sudo apt-get install libportaudio0:i386 libportaudio2:i386
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Then I tried:
$ sudo apt-get -f install
Correcting dependencies... Done
The following package was automatically installed and is no longer required:
  libaudit1:i386 libpam-modules:i386 libpam0g:i386 libportaudio0:i386 libstartup-notification0:i386 libxcb-util0:i386 sudo:i386
Use 'apt-get autoremove' to remove it.
The following extra packages will be installed:
The following packages will be REMOVED:
  guitarpro6:i386 sudo
0 upgraded, 2 newly installed, 2 to remove and 0 not upgraded.
1 not fully installed or removed.
Need to get 0 B/89.4 kB of archives.
After this operation, 109 MB disk space will be freed.
Is there a way that I can force the system to keep and use sudo while installing gksu as required by Guitar Pro 6? Why does apt insist on uninstalling guitarpro6:i386?
Offline mac
« Reply #3 on: May 14, 2014, 01:19:49 pm »
Dependency / conflict issues.  I would try installing aptitude and then try again with that.
sudo apt-get install aptitude
Just use "aptitude" in the place of "apt-get" such as.....
sudo aptitude install packagename
Then there is THIS
which suggests running.....
sudo dpkg -P --force-all --force-remove-reinstreq guitarpro6:i386
....but the thread dies with that and I don't know if that works or not so use at your own risk.
« Reply #4 on: May 14, 2014, 01:39:22 pm »
OK, again the issue crept closer to a solution. Here is where I am now:
$ sudo aptitude install gksu:i386
  gksu:i386 libaudit1:i386{a} libgksu2-0:i386{a} libgtop2-7:i386{ab} libpam-modules:i386{a} libpam0g:i386{a} libstartup-notification0:i386{a} libxcb-util0:i386{a} sudo:i386{ab}
0 packages upgraded, 9 newly installed, 0 to remove and 0 not upgraded.
Need to get 897 kB of archives. After unpacking 3,168 kB will be used.
 sudo : Conflicts: sudo:i386 but 1.8.6p3-0ubuntu3 is to be installed.
 sudo:i386 : Conflicts: sudo but 1.8.6p3-0ubuntu3 is installed.
 libgtop2-7 : Conflicts: libgtop2-7:i386 but 2.28.4-3 is to be installed.
 libgtop2-7:i386 : Depends: libgtop2-common:i386 (>= 2.28.4-3) which is a virtual package.
                   Conflicts: libgtop2-7 but 2.28.4-3 is installed.
The following actions will resolve these dependencies:
     Keep the following packages at their current version:
1)     gksu:i386 [Not Installed]
2)     libgksu2-0:i386 [Not Installed]
3)     libgtop2-7:i386 [Not Installed]
4)     sudo:i386 [Not Installed]
     Leave the following dependencies unresolved:
5)     libgksu2-0:i386 recommends sudo:i386
Unfortunately I don't have an overview of the consequences of these actions. Any ideas? After this gets resolved, I should be able to try to install Guitar Pro 6 again.
Offline mac
« Reply #5 on: May 14, 2014, 02:14:57 pm »
Should have thought of this earlier but .....  :-[
instead of using dpkg, open your Downloads folder and double-click the package and gdebi should install it while fixing dependecy issues (if possible).
« Reply #6 on: May 14, 2014, 02:26:54 pm »
It doesn't seem to be able to sort out the issue:
 guitarpro6
« Last Edit: May 14, 2014, 02:31:24 pm by globetrotterdk »
Offline mac
« Reply #7 on: May 14, 2014, 02:37:43 pm »
Okay, I'm downloading the trial version as we "speak" and will give it a try and see what I run into.  BBS...
Offline mac
« Reply #8 on: May 14, 2014, 03:14:45 pm »
Error: Cannot install gksu:i386
Well, I'm stumped........don't know anything else to suggest.  There is a way to remove the gksu:i386 dependency from the .deb file but I don't know how to do that, either.  Maybe someone more knowledgeable than I will chime in, shortly.
« Reply #9 on: May 14, 2014, 03:38:27 pm »
OK, no worries. Your effort is much appreciated.
Offline mac
« Reply #10 on: May 14, 2014, 08:30:27 pm »
Just a thought....
If you plan on installing P5 you could install the 32bit version which should eliminate your issues.   Or, if you need it now and are willing to go through it all, you can install P4 or P3 32bit.
Like I said, just a thought.... ???
« Reply #11 on: May 15, 2014, 06:23:33 am »
I prefer to stick with a 64-bit Peppermint OS (whether 4 or 5), but I have plenty of internal hard disks. I have considered installing elementary Linux or a vanilla Ubuntu, but I have been putting off this option as I have tried this once before and erased the working hard disk, rather than the intended hard disk. I have Peppermint OS 4, Salix and Win 7 installed  on my home built machine. How do I avoid formating the disks with Peppermint and Win 7? I am not sure where they are located.
I have gone into the grub menu edit mode under the individual menu items and my system looks like this:
Peppermint OS 4   -   hd1
Salix                    -   hd0
Ubuntu 12.04      -   hd2
Win 7         -   hd3
I am pretty sure that Ubuntu 12.04 is the the disk I reformatted, as the system can't find /home when it is booted up. Here are my concerns:
  • Installing to the correct hard disk.
  • Making sure I get a GRUB menu at startup (Ubuntu usually hides the menu).
  • Peppermint OS at the top of the list as the default system to boot into.
  • Removing all of the i386 libs that I just installed in my Peppermint OS system.
« Reply #12 on: May 15, 2014, 10:28:50 am »
If someone can bung a link to the trial on here, I'll see if I can tweak the dependencies and get it to work in 64bit.
Offline mac
« Reply #13 on: May 15, 2014, 10:57:59 am »
« Reply #14 on: May 15, 2014, 11:02:52 am »
Sounds good. Thanks for the initiative   :)
