Author Topic: UEFI on Dell Inspiron 15 5000  (Read 3680 times)
« on: December 07, 2015, 01:57:14 pm »
Hi all, I'm trying to help my son in Florida change the boot order on his Dell Inspiron 15 5000 Series.  It's one these funky UEFI jobs.  I have no experience with these.  Does anyone know what he has to do, so he can fire up a Live USB stick?  It is the 64-bit respin ISO.   What will he have to do to install Peppermint Six  as a dual boot with Windows 10?  Many thanks in advance  ;).
Re: UEFI on Dell Inspiron 15 5000
« Reply #1 on: December 07, 2015, 03:54:53 pm »
I recommend EasyBCD.  It can be installed in Windows and used to easily modify Windows' bootloader.  You can simply add boot entries for anything and change the boot order.
http://neosmart.net/EasyBCD/
« Reply #2 on: December 07, 2015, 07:03:28 pm »
EasyBCD aint gonna work in UEFI mode .. the boot process is totally different:
https://neosmart.net/wiki/easybcd/uefi/
He'll have to access the boot manager screen .. possibly the F12 key (immediately after turning on the PC)
« Last Edit: December 07, 2015, 07:06:24 pm by PCNetSpec »
« Reply #3 on: December 07, 2015, 07:59:54 pm »
According to the EasyBCD website, it works with Windows 10 and UEFI.  But, I don't know more than that because I got off the Windows train before UEFI.
« Reply #4 on: December 07, 2015, 11:06:40 pm »
Thanks guys, he's managed to boot into a Live Session.  I'll probably ask again when he wants to dual boot.  I think he'll need to make a Windows 10 rescue disk or something.  I'm so out of touch with Windows.  I want to make a custom Partition Table with a separate /DATA partition for him.  I'll use good old Team Viewer for that.  That shouldn't affect how I use GParted  :-\?
« Reply #5 on: December 08, 2015, 02:29:21 am »
Cool, they must have updated it then.
« Reply #6 on: December 08, 2015, 07:55:11 am »
Yeah, you always want to make a Windows Recovery disc before making any major changes to a Windows PC.  That way, if something gets messed up, he'll be able to return the computer to its original factory specs.
« Reply #7 on: December 08, 2015, 08:55:16 am »
http://www.laptopmag.com/articles/access-bios-windows-10
nice graphical process of getting into the uefi bios settings where you can then alter the boot order of the hdd.   You can also do this by holding down the "shift" key as you click on "restart"
I would not recommend making any changes in Live mode to the partition structure using gparted if windows 10 is involved.   In windows 10 Disk Management reduce the size of the windows partition making the free space you want for Peppermint, unless you fully understand the laptops partition structure (I don't on my Lenovo) just reduce the main Windows partition and leave all the rest as is.   Then when you boot Live, install as normal (carving up the free space you made as needed) and it will dual boot just fine (My Lenovo did).
Good Luck...
« Reply #8 on: December 08, 2015, 11:32:04 am »
Hi zebedeeboss, thanks for the info  ;).  Yeah, you've just confirmed what I was hoping to hear.  I can reduce the size of the main Windows partition and then carve it up using the Something Else option in the Ubiquity Installer.  That'll make a nice custom partition table.  I'll get him to make a Windows 10 rescue disk before he installs Peppermint Six just to play safe.  Thanks again for the help.  We do have a great forum  ;).
