Author Topic: Fix screen tearing on Intel graphics chips  (Read 24316 times)
Offline Thriceby5
Re: Fix screen tearing on Intel graphics chips
« Reply #30 on: December 14, 2018, 08:21:50 pm »
No I haven't and I wouldn't know how to. Im still fairly new to linux.
« Reply #31 on: December 15, 2018, 06:37:12 am »
Go to:-
Menu > Settings > Peppermint Control Center
Select the "Desktop Effects" tab.
Remove the tick from "Enable desktop effects".
« Last Edit: December 15, 2018, 06:39:30 am by PCNetSpec »
Offline Johan
« Reply #32 on: December 16, 2018, 12:59:42 pm »
Slightly different to fix screen tearing on Peppermint: https://static.afbeeldinguploaden.nl/1807/439104/U0AXQyWT.png
No need to tick off Enable desktop effects.
« Last Edit: December 16, 2018, 01:03:29 pm by Johan »
Offline Thriceby5
« Reply #33 on: December 21, 2018, 08:42:17 pm »
Sorry for the late reply. I tried PCNetSpec's method and it didn't work. Then I tried Johan's method only to get "Could not save file /usr/share/x11/xorg.conf.d/20-intel.conf.".
Picture attached is exactly what I got from Johan's method (I dont know how to attach images so im using imgur for now.).
https://imgur.com/a/MYUKd2n
« Reply #34 on: December 21, 2018, 11:19:24 pm »
The directory you are trying to save the file to its owned by root.
You have to use sudo to be able to save it.
Offline Thriceby5
« Reply #35 on: December 22, 2018, 12:31:02 am »
I did use sudo, just like the image instructed.
« Reply #36 on: December 22, 2018, 12:36:34 am »
Hi Thriceby5,
I did once come across a weird instance when a file would not save because the directories did not exist. they normally get saved as part of the file save process.
Therefore navigate to the desired directory tree and see if the directory you are trying to save to actually exists.  If not, create it and try to save the file again.
I hope this helps
« Reply #37 on: December 22, 2018, 09:50:31 am »
I think you need to force use of the "intel" driver instead of the "modesetting" driver.
Offline Thriceby5
« Reply #38 on: December 22, 2018, 03:10:14 pm »
Could any of you make a step by step process? Im still very new to linux.
« Reply #39 on: December 22, 2018, 03:11:34 pm »
It is a step-by-step process. It's all laid out in the first post of this thread.
Offline Johan
« Reply #40 on: December 22, 2018, 11:30:20 pm »
Very strange, because I followed the steps described on the image yesterday. Are you sure you typed in exactly the same as displayed, because I got the same error message only to find out I typed hsare instead of share. After I corrected it, it saved without error message and no more screen tearing.
At the end of /usr/share/x11/xorg.conf.d/20-intel.conf there is a . Remove the . after conf and try again. It has to be this: sudo gedit /usr/share/x11/xorg.conf.d/20-intel.conf not this: sudo gedit  /usr/share/x11/xorg.conf.d/20-intel.conf.
« Last Edit: December 23, 2018, 12:10:30 am by Johan »
« Reply #41 on: December 23, 2018, 06:01:30 am »
@Johan
I suspect your card is using the "intel" drivers, and not the "modesetting" drivers (?)
« Last Edit: December 23, 2018, 06:03:43 am by PCNetSpec »
Offline Johan
« Reply #42 on: December 24, 2018, 05:09:58 am »
I guess so, I don't even know what modesetting drivers are ??? Mine is: Intel HD Graphics 620 But I hope he will try to  /usr/share/x11/xorg.conf.d/20-intel.conf without the point after conf ;)
« Last Edit: December 24, 2018, 05:39:50 am by Johan »
« Reply #43 on: December 24, 2018, 08:02:31 am »
@Thriceby5
Try enabling "Synchronize drawing to the vertical blank" in:-
Menu > Settings > Peppermint Control Center > Desktop Effects (tab)
You may then need to reboot before testing.
Offline Johan
« Reply #44 on: May 18, 2019, 04:40:13 am »
This way it worked for me too to fix screen tearing on Pepp 10. And much quicker than the one I used before. So thanks Mark 8)
« Last Edit: May 18, 2019, 09:50:31 pm by Johan »
