Author Topic: What is it with shockwave flash? (SOLVED)  (Read 3914 times)
Offline Rens
  • IBM Thinkpad X30 tasting fresh
    • google+ profile
  • Peppermint version(s): 4
« on: May 11, 2014, 06:43:07 am »
My Chromium in pepermint 4 cannot load shockwave flash. I have tried the following:
sudo apt-get install ubuntu-restricted-extras
sudo apt-get install lubuntu-restricted-extras
and then removed and reinstalled the flashplayer with:
sudo apt-get remove flashplugin-installer
sudo apt-get install flashplugin-installer
I have then closed and reopened chromium but to no avail.
Under chromium plugins the only flashplayer plugin that is there is:
Adobe Flash Player - Version: 11.2 r202
Shockwave Flash 11.2 r202
Version:   11.2 r202
Location:   /usr/lib/flashplugin-installer/libflashplayer.so
Type:   NPAPI
     Disable
MIME types:
MIME type   Description   File extensions
application/x-shockwave-flash   Shockwave Flash
.swf
application/futuresplash   FutureSplash Player
.spl
Disable   Always allowed?
Kind regards,
Rens
« Last Edit: May 11, 2014, 09:05:51 am by Rens »
Re: What is it with shockwave flash?
« Reply #1 on: May 11, 2014, 06:50:12 am »
What's the output (if any) from:
cat /proc/cpuinfo | grep sse2
Offline Rens
    • google+ profile
« Reply #2 on: May 11, 2014, 06:56:16 am »
There is no output.
« Reply #3 on: May 11, 2014, 07:25:52 am »
OK, the latest flashplayer required sse2 support from your CPU but 11.1 was quite happy to work without it.
So..
The following asssumes you're using the 32bit version of Peppermint .. if you're running 64bit, both times you see 32bit in a command, change it to 64bit
First uninstall the current flashplayer:
sudo apt-get remove --purge flashplugin-installer
now create a plugins directory in the right place:
mkdir -p ~/.mozilla/plugins
cd into that directory:
cd ~/.mozilla/plugins
download the 11.1 version of flashplayer with:
wget https://dl.dropboxusercontent.com/u/11876059/flashplayer-11.1-32bit.tar.gz
extract the archive
tar xvf flashplayer-11.1-32bit.tar.gz
now close ALL web browser instances .. then reopen Chromium to test.  <--- It's important you close ALL web browser instances before reloading Chromium
« Last Edit: May 11, 2014, 07:28:40 am by PCNetSpec »
Offline Rens
    • google+ profile
« Reply #4 on: May 11, 2014, 09:04:44 am »
That did the job! Wonderful! Thank you very much!
Re: What is it with shockwave flash? (SOLVED)
« Reply #5 on: May 11, 2014, 09:13:37 am »
You're most welcome .. thanks for marking the topic solved :)
Offline damig
  • PeppermintOS daily user
« Reply #6 on: May 20, 2014, 02:23:19 pm »
PCNetSpec, there is an output with mine:
damig@damig-Satellite-A75 ~ $ cat /proc/cpuinfo | grep sse2
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe constant_tsc pebs bts pni dtes64 monitor ds_cpl est tm2 cid xtpr
« Reply #7 on: May 20, 2014, 04:12:03 pm »
@ damig
Yours should "just work" then .. if it's not, can you start a new topic please.
Offline damig
« Reply #8 on: May 20, 2014, 04:23:49 pm »
duh... it was just my inner animal. Sorry about this, and I'll leave it for other noobs
Sent from my GT-S6310 using Tapatalk
