Author Topic: Holtek mouse support (SOLVED)  (Read 11259 times)
« on: October 23, 2015, 02:46:41 am »
Hi guys
Recently I installed PM6 to a friends Toshiba Satellite and it works fine but he's asked me to see if I can get his USB mouse working,
The mouse is a Holtek gaming mouse there's no model name or number I can see but it's listed in lsusb as a Holtek
when plugged in it lights up but no activity
any ideas ?
scott@Scotts-Laptop ~ $ lsusb
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 003: ID 04f2:b307 Chicony Electronics Co., Ltd
Bus 001 Device 005: ID 04d9:a071 Holtek Semiconductor, Inc.
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
scott@Scotts-L
aptop ~ $
Many thanks
« Last Edit: October 26, 2015, 01:27:24 pm by emegra »
Re: Holtek mouse support
« Reply #1 on: October 23, 2015, 06:38:04 am »
Well, their site is certainly no help.  They have one driver for all of their peripherals and it's an .exe file.   ::)
Have you tried the Ubuntu or Mint forums to see if anyone has started a thread about this brand of mouse before?  It may be worth a look in case there is a posted solution.
« Reply #2 on: October 23, 2015, 06:54:50 am »
Hi scifidude
Thanks for your reply
You're right their site is useless at least as far as Linux support is concerned
I've been all over the internet, and I can't find a solution anywhere at least not one that doesn't require a computer science degree, there was a similar question on the Mint forums but it ended inconclusively and to make matters even more complicated I'm not 100% sure of the model but I think it's a Sharkoon Draconia.
this post here will give some idea what I mean by "in depth"
Many thanks
« Reply #3 on: October 23, 2015, 07:56:36 am »
Hm, sounds like a huge PITA. I wish I could be some help, bro, but all of my peripherals are plug and play compatible.  Though, I'll know to stay away from that brand of gaming mouse.  ;)  I suppose your friend wouldn't want to buy a different brand of mouse.  I mean, I know how we gamers are about our stuff, we want certain things and nothing else will do.
« Reply #4 on: October 23, 2015, 08:17:29 am »
The thing is I told him from the get go he wouldn't be able to game on Linux at least not the games he might be used to and he said he didn't care about that, he just wanted off Windows,
You're right this is a pain in the arse if he's not going to game with it the mouse has no advantages over any other normal mouse, as far as I can see, but that said I would still like to get it to work for pride sake if nothing else but if it's not to be then  I'll just have to tell him to get another mouse or go back to Windows
Offline darknet
  • /home/darknet
  • Peppermint version(s): Peppermint 10 respin 64-bit
« Reply #6 on: October 23, 2015, 09:09:55 am »
Hi Drum
I've seen at least one of the sites you posted but I really don't know what to make of that info or what to do with it  it's a bit out of my depth but it does give some hope it might be possible to get this mouse working, hopefully someone can make sense of the information and guide me
Anyway thanks for taking the time to help and post the links
« Reply #7 on: October 23, 2015, 09:28:14 am »
OK, it seems like it's probably quite an easy fix:
https://forums.opensuse.org/showthread.php/473200-USB-Gaming-Mouse-04d9-a078-not-working-in-linux-plus-workaround
Just change a single value in hid.h, then recompile the kernel.
Erm, who said Linux was easier  :o
« Last Edit: October 23, 2015, 09:29:52 am by PCNetSpec »
« Reply #8 on: October 23, 2015, 09:52:04 am »
ok couple of problems
there is no hid.h file at /usr/src/linux/include/linux instead I have 6 linux-headers folders 3.16.0-46 + generic, 3.16.0-50 + generic & 3.16.0-51 + generic
presumably I have to follow these instructions in one of these folders the question is which one ?
In /usr/src/linux/include/linux/hid.h
change the value of the constant in line 344
Code:
#define HID_MAX_USAGES                        12288
from 12288 to a value greater than 32k,
recompile and install the new kernel.
and then how do I recompile the kernel ?
many thanks
« Reply #9 on: October 23, 2015, 10:52:10 am »
Download the current kernel source to your home folder:
cd ~/then
apt-get source linux-image-$(uname -r)now install the build dependencies:
sudo apt-get build-dep linux-image-$(uname -r)now make your edit to this file:
gedit ~/linux-lts-utopic-3.16.0/include/linux/hid.hthen compile the kernel:
cd ~/linux-lts-utopic-3.16.0then
fakeroot debian/rules cleanthen
fakeroot debian/rules binary-headers binary-genericand go to the pub whilst it compiles
see here:
https://wiki.ubuntu.com/Kernel/BuildYourOwnKernel
« Reply #10 on: October 23, 2015, 11:23:46 am »
ok before I head off to the pub
this will probably be a stupid question but I'm gonna ask it anyway
why couldn't I just make the same edit to the current kernel at  /usr/src/linux/include/linux ?
« Reply #11 on: October 23, 2015, 11:42:43 am »
because that's not the kernel .. it's just the header files (info that applications you may manually compile need to compile correctly), it is NOT the complete kernel source code.
« Reply #12 on: October 23, 2015, 12:42:40 pm »
Ok I followed your instructions and rebooted but still no mouse activity, is there anything I have to do ?
« Reply #13 on: October 23, 2015, 01:00:38 pm »
Did you install the generated .deb packages ?
Have you rebooted to the new kernel ?
Is it running your custom kernel ?
What's the output from:
uname -a
« Last Edit: October 23, 2015, 01:03:25 pm by PCNetSpec »
« Reply #14 on: October 23, 2015, 01:10:27 pm »
No i Didn't install anything, there's a few .deb packages in my home folder, do I have to install all these packages ?
I rebooted immediately after it finished recompiling buit I don't know what kernel I booted into
I have no idea
I will post post the out put to uname -a in a few minutes by edit to this post
scott@Scotts-Laptop ~ $ uname -a
Linux Scotts-Laptop 3.16.0-51-generic #69~14.04.1-Ubuntu SMP Wed Oct 7 15:32:41 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
« Last Edit: October 23, 2015, 01:22:11 pm by emegra »
