Author Topic: 8 in 1 SD Card Reader problem  (Read 4320 times)
Offline geminimoon66
  • Peppermint version(s): Peppermint 4
« on: May 05, 2014, 11:22:19 am »
I have an eMachine T5026 running Peppermint 4.  Just bought a new SanDisk SDHC 16GB Card and I cannot get this desktop to see the card, although it reads other SD cards fine. (Card works fine in my camera and is readable in laptop with Win Vista, just not on my desktop)
Someone said this card reader may not read an SDHC card.  How can I find out what card reader this PC has, I checked eMachine site and it only says it's an 8 in 1 card reader.
Just not sure what to do or try in this case.
Any help is greatly appreciated!!!
~GM66
Re: 8 in 1 SD Card Reader problem
« Reply #1 on: May 05, 2014, 11:44:43 am »
"Someone" is probably right .. the card reader may only be able to read SD not SDHC
What's the output from:
lsusb
run in a terminal.
I've also seen SD cards that have been formatted (out of the factory) without a partition .. oddly Windows ignored this and they worked even though it was breaking accepted standards.
In Linux the card was seen, but wouldn't mount.
so also (with the card inserted) post the output from:
sudo fdisk -l
can you also, remove the card .. wait 10 seconds .. reinsert the card .. now post the output from:
dmesg | tail -n 20
« Reply #2 on: May 05, 2014, 12:52:15 pm »
Thanks for the quick response, as usual!
output
~ $ lsusb
Bus 003 Device 002: ID 0461:4d64 Primax Electronics, Ltd
Bus 003 Device 003: ID 058f:9360 Alcor Micro Corp. 8-in-1 Media Card Reader
Bus 005 Device 002: ID 046d:c318 Logitech, Inc. Illuminated Keyboard
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
~ $ sudo fdisk -l  (with the card inserted)
Disk /dev/sda: 20.0 GB, 20020396032 bytes
255 heads, 63 sectors/track, 2434 cylinders, total 39102336 sectors
Disk identifier: 0x0007e6de
/dev/sda1   *        2048    36012031    18004992   83  Linux
/dev/sda2        36014078    39100415     1543169    5  Extended
/dev/sda5        36014080    39100415     1543168   82  Linux swap / Solaris
Disk /dev/sdb: 160.0 GB, 160041885696 bytes
255 heads, 63 sectors/track, 19457 cylinders, total 312581808 sectors
Disk identifier: 0x0002a581
/dev/sdb1              63   312581807   156290872+  83  Linux
~ $ dmesg | tail -n 20
[   60.732031] usb 3-2: reset full-speed USB device number 3 using uhci_hcd
[   70.992031] usb 3-2: reset full-speed USB device number 3 using uhci_hcd
[   71.145430] sd 4:0:0:0: Device offlined - not ready after error recovery
[   71.145483] sd 4:0:0:0: rejecting I/O to offline device
[   71.145497] sd 4:0:0:0: rejecting I/O to offline device
[   71.145506] sd 4:0:0:0: rejecting I/O to offline device
[   71.145512] sd 4:0:0:0: [sdc] READ CAPACITY failed
[   71.145515] sd 4:0:0:0: [sdc]
[   71.145519] Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK
[   71.145521] sd 4:0:0:0: [sdc] Sense not available.
[   71.145529] sd 4:0:0:0: rejecting I/O to offline device
[   71.145536] sd 4:0:0:0: [sdc] Write Protect is off
[   71.145540] sd 4:0:0:0: [sdc] Mode Sense: 00 00 00 00
[   71.145545] sd 4:0:0:0: rejecting I/O to offline device
[   71.145551] sd 4:0:0:0: [sdc] Asking for cache data failed
[   71.145554] sd 4:0:0:0: [sdc] Assuming drive cache: write through
[   71.147472] sd 4:0:0:0: [sdc] Attached SCSI removable disk
[   71.348352] sd 4:0:0:2: [sde] Attached SCSI removable disk
[   71.353363] sd 4:0:0:3: [sdf] Attached SCSI removable disk
[   71.358358] sd 4:0:0:1: [sdd] Attached SCSI removable disk
(card removed, 10 sec. wait... card re-inserted:)
Lots of greek there to me but I know you know what you're doing!  At the very least, I now know what type of device the card reader is(Alcor Micro Corp. 8-in-1 Media Card Reader).
When I open "Disks" to see my drives it only shows the SD Card Reader as Generic USB SD Reader (1.00),  is it possible to update or install the driver for that card?
 Awaiting your next suggestion!
Thanks!
~GM66
« Last Edit: May 05, 2014, 01:21:39 pm by mac »
« Reply #3 on: May 05, 2014, 12:54:37 pm »
Oops!  I added the ~ $ dmesg | tail -n 20 output twice...
« Reply #4 on: May 06, 2014, 05:24:37 am »
I can find quite a few pages such as these:
http://forums.bodhilinux.com/index.php?/topic/4620-solved-alcor-micro-corp-8-in-1-media-card-reader-not-showing-in-file-manager/
http://ubuntuforums.org/archive/index.php/t-1136196.html
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1069289
So I can only presume the card reader cannot handle high capacity SD cards (SDHC)
You'll need to get an external (or internal) SDHC reader.
see:
http://lmgtfy.com/?q=058f%3A9360+sdhc
« Last Edit: May 06, 2014, 05:27:23 am by PCNetSpec »
