Author Topic: Problem with based distros in ubuntu and arch  (Read 2530 times)
Offline sskarma
Re: Problem with based distros in ubuntu and arch
« Reply #15 on: September 29, 2015, 08:37:33 am »
Hola amigo, just saying but have you checked the resolution of the image before setting it as wallpaper? Are you sure you aren't setting a lower resolution image (say 400x400) as wallpaper? because your display (icons and OSD) looks fine to me. Only your wallpapers are broken. Please check the resolution and image size of an image before setting it as wallpaper and make sure if it's okay. Gracias
