Author Topic: (SOLVED) get torrent asks for launcher ?  (Read 15137 times)
Online PCNetSpec
Re: get torrent asks for launcher ?
« Reply #15 on: May 06, 2014, 02:11:02 pm »
OK, run these commands in sequence:
xdg-mime default transmission-gtk.desktop application/x-bittorrent
xdg-mime default transmission-gtk.desktop x-scheme-handler/magnet
cd /usr/bin
sudo wget https://dl.dropboxusercontent.com/u/11876059/xdg-open-magnet-fix.tar.gz
sudo tar xvf xdg-open-magnet-fix.tar.gz
Now REBOOT.
Once rebooted, test xdg-open opens transmission for magnet links with:
xdg-open "magnet:?xt=urn:btih:00f31997b0240ef6235271ae80a95ea402055bdb"
that should open transmission and after you click Open should download
Linux Shell Scripting with Bash.pdf
If that works .. try a magnet link in Chromium or Chrome.
Offline penrose1950
« Reply #16 on: May 06, 2014, 03:42:04 pm »
i got this error but when i clicked on the magnet it brought the launcher up and i clicked on it i think it said use this launcher from now on and it worked
WARNING: gnome-keyring:: couldn't connect to: /run/user/john/keyring-DKLV1Q/pkcs11: No such file or directory
Online PCNetSpec
« Reply #17 on: May 06, 2014, 03:52:12 pm »
Ignore the gnome-keyring warning, it's not important.
Are magnet links now working in Chromium ?
Offline penrose1950
« Reply #18 on: May 07, 2014, 11:52:31 am »
yes all good,thank you very much for your help.
Online PCNetSpec
Re: (SOLVED) get torrent asks for launcher ?
« Reply #19 on: May 07, 2014, 12:33:51 pm »
No problem .. cheers for marking the topic solved :)
Offline Hasimir0
  • Just Wandering Around
    • UnPlayableGames.tk
  • Peppermint version(s): Peppermint 4
« Reply #20 on: July 19, 2014, 07:43:47 am »
Thanks a LOT also from me... it worked! :D
Online PCNetSpec
« Reply #21 on: July 19, 2014, 09:12:52 am »
You're welcome too :)
