Author Topic: How to turn off transparency on "inactive" monitor (SOLVED)  (Read 1192 times)
Offline YeeP
  • Peppermint version(s): 6
« on: September 19, 2015, 11:30:35 pm »
Hello. When I first started using peppermint I thought it was actually kind of cool, but being that I used two monitors all the time for web development and pretty much everything else I have run into a problem with this. I will have multiple programs stacked on top of each other on the monitor I am not currently active on, while looking at the other. I turn my head slightly to read some of the code I am looking to modify on the inactive monitor, and it is nearly impossible to read because of what this is doing. How can I set this up so everything stays fully opaque even when I am on the other monitor?
Thank you.
« Last Edit: September 20, 2015, 09:51:33 am by YeeP »
Re: How to turn off transparency on "inactive" monitor
« Reply #1 on: September 20, 2015, 04:52:30 am »
menu > Preferences > Peppermint Control Center > Desktop Effects (tab)
remove the tick from "Enable desktop effects" .. or play with the sliders.
Offline YeeP
« Reply #2 on: September 20, 2015, 09:51:09 am »
Got it, thanks for the tip. It is a cool effect for sure but when I need to use both monitors quite a bit I find it difficult to read the inactive monitor.
Re: How to turn off transparency on "inactive" monitor (SOLVED)
« Reply #3 on: September 20, 2015, 10:31:56 am »
You're most welcome, glad I could help :)
(thanks for marking the topic solved)
