Author Topic: Acer Aspire One 532h  (Read 2628 times)
Offline madentaiwn
  • Peppermint version(s): PM6
« on: September 17, 2015, 09:24:16 am »
Sound and Wifi works off the bat. the only thing I noticed is that not all the function keys work.  example Fn+F8 = mute for me.  It mutes the sound but will not unmute.  But those are really minor things
Details of the netbook is below. thanks PM team
feitastic@feitastic-AO532h ~ $ inxi -F
System:    Host: feitastic-AO532h Kernel: 3.16.0-49-generic i686 (32 bit) Desktop: N/A Distro: Peppermint Six
Machine:   Mobo: Acer model: AO532h version: V1.15 Bios: Acer version: V1.15 date: 01/14/2010
CPU:       Single core Intel Atom CPU N450 (-HT-) cache: 512 KB flags: (lm nx pae sse sse2 sse3 ssse3)
           Clock Speeds: 1: 1666.00 MHz 2: 1666.00 MHz
Graphics:  Card: Intel Atom Processor D4xx/D5xx/N4xx/N5xx Integrated Graphics Controller
           X.Org: 1.16.0 drivers: intel (unloaded: fbdev,vesa) Resolution: 1024x600@60.1hz
           GLX Renderer: Mesa DRI Intel IGD x86/MMX/SSE2 GLX Version: 1.4 Mesa 10.3.2
Audio:     Card: Intel NM10/ICH7 Family High Definition Audio Controller driver: snd_hda_intel
           Sound: Advanced Linux Sound Architecture ver: k3.16.0-49-generic
Network:   Card-1: Qualcomm Atheros AR9285 Wireless Network Adapter (PCI-Express) driver: ath9k
           IF: wlan0 state: up mac: c4:17:fe:c9:5a:27
           Card-2: Qualcomm Atheros AR8132 Fast Ethernet driver: atl1c
           IF: eth0 state: down mac: 70:5a:b6:2d:6b:b7
Drives:    HDD Total Size: 160.0GB (3.4% used) 1: id: /dev/sda model: ST9160314AS size: 160.0GB
Partition: ID: / size: 19G used: 5.2G (30%) fs: ext4 ID: swap-1 size: 4.00GB used: 0.02GB (0%) fs: swap
Sensors:   System Temperatures: cpu: 46.0C mobo: N/A
Info:      Processes: 151 Uptime: 21:48 Memory: 706.2/2009.0MB Client: Shell (bash) inxi: 1.9.17
New to the linux world
Re: Acer Aspire One 532h
« Reply #1 on: September 17, 2015, 02:34:54 pm »
Try this .. run:
sudo gedit /etc/asound.confwhen a BLANK file opens, make it read
pcm.pulse {
    type pulse
ctl.pulse {
    type pulse
pcm.!default {
    type pulse
ctl.!default {
    type pulse
SAVE the file and exit gedit
log off/on (or reboot)
test your mute key now toggles mute/unmute
Offline madentaiwn
« Reply #2 on: September 19, 2015, 09:59:20 pm »
That worked.  Thanks
« Reply #3 on: September 20, 2015, 02:20:39 am »
No problem :)
Offline madentaiwn
« Reply #4 on: September 21, 2015, 05:29:39 pm »
Try this .. run:
pcm.pulse {
    type pulse
ctl.pulse {
    type pulse
pcm.!default {
    type pulse
ctl.!default {
    type pulse
BTW, This fix also worked on my Asus laptop (U50F) that I posted before.
« Reply #5 on: September 22, 2015, 03:26:41 am »
Yeah, it works on my Samsung laptop too :)
It would be interesting to know if it works for everyone .. including if there  are any adverse effects for people that aren't having problems in the first place (?)
« Last Edit: September 22, 2015, 03:30:08 am by PCNetSpec »
Offline s4w3d0ff
  • Spray and Pray
    • Github
  • Peppermint version(s): Peppermint 7even 64bit UEFI
« Reply #6 on: September 22, 2015, 10:15:00 am »
Worked on my custom rig using an Apple keyboard  :D
Don't ask why I am using a Apple keyboard...   ::)
Linuxize IT!
BTC: 15D8VaZco22GTLVrFMAehXyif6EGf8GMYV
« Reply #7 on: September 22, 2015, 01:09:05 pm »
Cheers :)
