Author Topic: "S to skip mount, M to manual..." on P6 start, help  (Read 3419 times)
Offline gychang
  • Peppermint version(s): 6
« on: September 16, 2015, 04:01:09 pm »
When I boot into P6, I always get warning on first screen, usually I enter S and seems to proceed.  I  am trying to mount NTFS partition (Data) but does not automount and can not access from Nemo.
here is my /etc/fstab:
# / was on /dev/sdc6 during installation
UUID=7603b1e3-26e7-4706-984f-614119736c81 /               ext4    noatime,errors=remount-ro 0       1
# /boot/efi was on /dev/sdc2 during installation
UUID=8A7D-5288  /boot/efi       vfat    defaults        0       1
# swap was on /dev/sdc5 during installation
UUID=9ac3e962-d444-4c5b-a29e-b33c8778a815 none            swap    sw              0       0
/dev/disk/by-uuid/0C3F9CB82E076DC7 /mnt/0C3F9CB82E076DC7 auto nosuid,nodev,nofail,x-gvfs-show 0 0
thanks in advance
« Last Edit: September 22, 2015, 04:32:00 pm by gychang »
Re: "S to skip mount, M to manual..." on P6 start, help
« Reply #1 on: September 16, 2015, 04:11:15 pm »
Hi gychang, can you please provide some more information?  Please run the following commands in a terminal window and post the outputs back to the forum:
sudo fdisk -l followed by:
sudo blkidPlease remember to encapsulate the outputs with the # Insert Code function.  This preserves the original output.  This function is found above the,  :-[ Embarrassed emoticon in the forum editor - many thanks  ;).
Offline gychang
« Reply #2 on: September 17, 2015, 05:28:55 am »
I ended up reinstalling the P6, now working fine.  thanks,
« Reply #3 on: September 17, 2015, 12:01:16 pm »
Well that was a bit drastic, all for a single malformed line in fstab .. but whatever works for you ;)
« Last Edit: September 17, 2015, 12:06:57 pm by PCNetSpec »
Offline gychang
« Reply #4 on: September 18, 2015, 04:47:10 am »
reinstalled P6, worked for one day and now the same problem.
fdisk -l
apa@main ~ $ sudo fdisk -l
[sudo] password for apa:
Disk /dev/sda: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors/track, 121601 cylinders, total 1953525168 sectors
Disk identifier: 0xe9c64868
/dev/sda1               1  1953525167   976762583+  ee  GPT
Partition 1 does not start on physical sector boundary.
WARNING: GPT (GUID Partition Table) detected on '/dev/sdb'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/sdb: 120.0 GB, 120034123776 bytes
255 heads, 63 sectors/track, 14593 cylinders, total 234441648 sectors
Disk identifier: 0x00000000
/dev/sdb1               1   234441647   117220823+  ee  GPT
sudo blkid
apa@main ~ $ sudo blkid
/dev/sda1: LABEL="Data" UUID="58DE2D0079E8B3D3" TYPE="ntfs"
/dev/sdb1: LABEL="Recovery" UUID="723E7C403E7BFB83" TYPE="ntfs"
/dev/sdb2: UUID="8A7D-5288" TYPE="vfat"
/dev/sdb4: UUID="D204B7B004B79647" TYPE="ntfs"
/dev/sdb5: UUID="E47C2A917C2A5F14" TYPE="ntfs"
/dev/sdb6: UUID="9ac3e962-d444-4c5b-a29e-b33c8778a815" TYPE="swap"
/dev/sdb7: UUID="c5d87df0-f1bb-467b-bbd7-0e7a5bbcc780" TYPE="ext4"
/dev/sda1 is not automounting...
how to fix this?
« Reply #5 on: September 18, 2015, 05:00:35 am »
Backup fstab:
sudo cp -v /etc/fstab /etc/fstab.baknow create a mountpoint:
sudo mkdir -p /media/Datamake sure you have ntfs-3g installed:
sudo apt-get install ntfs-3gnow open fstab for editing:
sudo gedit /etc/fstaband add the 2 NEW lines at the bottom:
## Mount Data partition (/dev/sda1) manually added by gychang
UUID=58DE2D0079E8B3D3  /media/Data  ntfs-3g  defaults,windows_names,locale=en_US.utf8  0 0
SAVE the file and exit gedit
run:
sudo mount -aand if there were no errors .. reboot to test
NOTE - whilst in fstab, remove any line you previously added to automount dsa1
Offline gychang
« Reply #6 on: September 18, 2015, 09:31:32 pm »
Backup fstab:
run:
I am still getting errors when I enter sudo mount -a
apa@main ~ $ sudo mount -a
The disk contains an unclean file system (0, 0).
Metadata kept in Windows cache, refused to mount.
Failed to mount '/dev/sda1': Operation not permitted
The NTFS partition is in an unsafe state. Please resume and shutdown
Windows fully (no hibernation or fast restarting), or mount the volume
read-only with the 'ro' mount option.
« Reply #7 on: September 18, 2015, 09:59:23 pm »
Hi gychang, What's the content of your fstab file?  Run the following command and post the output back to the forum:
gedit /etc/fstab
« Reply #8 on: September 19, 2015, 04:01:02 am »
reboot into Windows and run:
chkdsk /fto fix the Windows filesystem errors
Offline gychang
« Reply #9 on: September 19, 2015, 06:20:44 am »
am dual booting, on my windows 10, I did chkdsk D: /f /r /x and now it does load sda (NTFS) disk, and all works, BUT I still get the "S to skip mount..." and have to enter S and proceed to booting into P6.  Can it that my sda and sdb is reversed on my PC (have OS-win 10, P6 on mSATA - sdb, and my Data HD-NTFS is on sda) or can it be grub-customizer?
thanks for all the help so far...
« Reply #10 on: September 19, 2015, 07:01:49 am »
Give us the contents of:
gedit /etc/fstaband the output from:
sudo fdisk -land
sudo blkid
Offline gychang
« Reply #11 on: September 19, 2015, 09:01:50 am »
sudo fdisk -land
sudo blkid
fstab:
# / was on /dev/sdb6 during installation
UUID=c5d87df0-f1bb-467b-bbd7-0e7a5bbcc780 /               ext4    errors=remount-ro 0       1
# /boot/efi was on /dev/sdb2 during installation
# swap was on /dev/sdb5 during installation
/dev/disk/by-uuid/58DE2D0079E8B3D3 /mnt/58DE2D0079E8B3D3 auto nosuid,nodev,nofail,x-gvfs-show 0 0
blkid
fdisk -l
thanks,
« Reply #12 on: September 19, 2015, 01:28:17 pm »
run:
sudo gedit /etc/fstaband make it read:
SAVE the file .. reboot to test.
Offline gychang
« Reply #13 on: September 19, 2015, 03:01:07 pm »
works!, thanks.
what was wrong?, fstab am sure has to do with NTFS HD not properly being mounted.
run:
Offline gychang
Re: "S to skip mount, M to manual..." on P6 start, help (SOLVED)
« Reply #14 on: September 19, 2015, 03:01:23 pm »
thanks in advance
