Author Topic: dual monitor support  (Read 6805 times)
Offline rmcellig
« on: May 01, 2014, 03:27:42 am »
How does Peppermint handle dual monitor support. I want to be able to drag items from one monitor to the other instead of a cloned monitor display.
Re: dual monitor support
« Reply #1 on: May 01, 2014, 06:37:37 am »
If you have an nVidia or ATI graphics card and are using the nvidia or fglrx  .. you should be able to adjust your dual monitors in the nvida settings or catalyst control centre respectively.
If you're NOT using the proprietary drivers, or have a different make of card....
you might want to install arandr:
sudo apt-get install arandrthen go to:-
menu > Preferences > ARandR
When it starts I suspect your 2 monitors will be positioned over the top of each other .. dgar one to the side of the other.
Then click:-
Layout > Apply
When you have it set and working the way you want, click
Layout > Save As
and give it a name such as "dual-monitors.sh" .. and save it.
That profile can then be easily loaded from ARandR .. or even set to autostart with the desktop.
Offline condottiere
  • Peppermint version(s): 5
« Reply #2 on: January 24, 2015, 02:26:47 pm »
I'm trying this out, by sticking both the HDMI and VGA plugs into a Sharp TV.
The VGA resolution seems maximized at 1024 x 768. Apparently, with or without dual monitoring.
Intel Ivy Celeron dual two point six
Asus ITX
Ten gigabytes RAM
Raptor one fifty gigabytes
Offline YeeP
  • Peppermint version(s): 6
« Reply #3 on: September 09, 2015, 11:21:01 am »
PCNetSpec: I have used this method and have two scripts now, one for when I have both monitors in use, and one for when the laptop is not plugged into the other monitor on my desk.
Is there a method that can be used to detect if the second monitor is plugged in via scripting? I would like to run an autostart that runs the proper script based on what it finds.
Thoughts?
« Reply #4 on: September 09, 2015, 02:51:55 pm »
You might want to see here:
http://unix.stackexchange.com/questions/4489/a-tool-for-automatically-applying-randr-configuration-when-external-display-is-p
if you look at the post about the udev script, and how to check if you're getting a udev "event" when the monitor is attached or not.
if you DO get the udev event, take a look at the posting with this script:
#!/bin/sh
dmode="$(cat /sys/class/drm/card0-VGA-1/status)"
export DISPLAY=:0
export XAUTHORITY=/home/yourusername/.Xauthority
if [ "${dmode}" = disconnected ]; then
     /usr/bin/xrandr --auto
elif [ "${dmode}" = connected ];then
     /usr/bin/xrandr --output VGA1 --auto --right-of LVDS1
else /usr/bin/xrandr --auto
fi
check if when the monitor is NOT attached
cat /sys/class/drm/card0-VGA-1/statusreturns "disconnected"
but it returns something else when the monitor IS attached.
if it does, you could slightly modify that script to use YOUR xrandr command line (in your arandr scripts), and use a combination of the udev rule and that modified script to trigger the switch as the monitor is attached/detached
this is what I love about Linux .. roll your own solutions :)
Offline YeeP
« Reply #5 on: September 09, 2015, 06:07:29 pm »
Cool, good ideas and I will play around with them to see what I can come up with.
Thanks!
Offline 928
« Reply #6 on: November 21, 2015, 11:54:06 pm »
Спасибо, моя проблема решена.
« Reply #7 on: November 22, 2015, 01:52:55 am »
Вы только приветствовать :)
