Author Topic: Successfully mounting Android devices in Peppermint 3  (Read 2448 times)
Offline xanadu
  • Peppermint version(s): Peppermint 6
« on: April 29, 2014, 10:29:09 pm »
When I plug my Samsung Galaxy S4 into my computer, it automatically mounts, and I can see a folder structure, but there are no files in any of the folders. Also, in pcmanfm, there are 8 different entries for the device:
Do I need something additional to be able to view and modify the files on my Android device in Peppermint 3?
I tried a suggestion elsewhere involving mtpfs, but didn't have any luck.
Offline mac
Re: Successfully mounting Android devices in Peppermint 3
« Reply #1 on: April 29, 2014, 10:57:39 pm »
Check out Airdroid.....free Google play app (file sharing, etc., via wifi)
Can't explain the pcmanfm behavior
Reg. Linux User #432835
Offline xanadu
« Reply #2 on: April 30, 2014, 09:18:51 am »
I used AirDroid a few years ago, it was beta then, had limited functionality. I'll have to check it out again.
Offline mac
« Reply #3 on: April 30, 2014, 04:56:47 pm »
It has improved quite a bit recently.  I use it almost exclusively along with the occasional usb stick.
« Reply #4 on: April 30, 2014, 05:01:20 pm »
Yeah I agree with mac here
Airdroid is amazing it can do anything you can do with a wired connection and it's so easy to use and they've even recently added a theming application
