Author Topic: re-designing partitioning on drive that holds Linux  (Read 1867 times)
« on: September 01, 2015, 04:51:19 am »
Hi
I have a number of partitions that I now want to get rid of and just have Peppermint6 and A.n.Other distro installed.   This will allow me to re-size the partitions as well.
Is it a simple case of removing the older partitions and moving root and home to a new location and with a bigger size ? Currently 12 / 24   I was thinking 25 and 75. bios_grub (I cant remember why I created a grub_bios partition {maybe whilst distro hopping one of them needed it}) and swap will stay where they are.  I am also assuming I will have to do this with a separate booted gparted ISO USB stick
I seem to remember being able to do something like this in GParted ?  http://gparted.org/display-doc.php?name=moving-space-between-partitions
Worst case scenario... re-install Peppermint
Advise and guidance please  ;D
Re: re-designing partitioning on drive that holds Linux
« Reply #1 on: September 01, 2015, 06:19:32 am »
Hi zebedeeboss,
Your link looks very good. Gparted is the way to go and you are best to run it in from a live session (e.g. from your Peppermint Six USB installation medium) because you should NEVER modify a mounted partition (like the one running Peppermint Six after booting into the installed version).
As AndyInMokum will confirm: backup, backup and BACKUP  your important data just in case some does go wrong!
If you end up moving your Peppermint Six root (/) partition you will need to go into grub and have it point to the new partition (it will have a different name if you move it: for example it might have been on /dev/sda5 and after resizing & deleting partitions and then moving Peppermint Six to a new partition (let's say it now is on /dev/sda3) then grub will not know this unless you change the scripts or reinstall grub).
Have fun and don't forget: backup!
« Reply #2 on: September 01, 2015, 08:12:03 am »
Thanks Slim.Fatz
That all went swimmingly well.  One quick trip into a grub rescue iso to boot into Peppermint 6.
Then used Grub-customizer to re-find everything and re-install grub  and viola....  here we are and all seems good and Well.
« Reply #3 on: September 01, 2015, 08:26:54 am »
Great stuff guys .. happy it all went well and you're back with us with a larger Peppermint.
Actually, now you have a larger Peppermint, can I have some of it .. I only have half a Peppermint on my menu button and I want a full one.
« Reply #4 on: September 01, 2015, 11:34:35 am »
Help yourself big fella   ;D ;D ;D
seems apply named too  :P
« Reply #5 on: September 01, 2015, 12:01:52 pm »
« Reply #6 on: September 01, 2015, 12:22:11 pm »
WOW!! I'll take some of that as well!!
--Slim
« Reply #7 on: September 01, 2015, 12:30:34 pm »
That's better....
