Author Topic: I/O scheduler Question - [Solved - Answered]  (Read 1284 times)
« on: August 24, 2015, 04:05:07 am »
Hi
Given my current setup http://forum.peppermintos.com/index.php/topic,1954.0.html
What will work best CFQ / NOOP or Deadline
Will it impact on the use of the USB drives or is it a case of tweaking for the sake of tweaking and leave well alone on default ? Can it make that much difference or is it again subjective and very much based upon how you use the pc?
Thanks in Advance
« Last Edit: August 25, 2015, 09:47:22 am by zebedeeboss »
Re: I/O scheduler Question
« Reply #1 on: August 25, 2015, 07:57:47 am »
If you don't have an SSD,  you're probably better off sticking with CFQ .. in fact you may be anyway but yeah it's all subjective...
http://www.phoronix.com/scan.php?page=article&item=linux_iosched_2012&num=1
