Author Topic: Ubuntu tweak and PM 6 (solved)  (Read 2015 times)
Offline ooseven
  • Peppermint version(s): 5
« on: August 09, 2015, 05:52:51 am »
Hello I have been using ubuntu tweak for years with no problems. Now when I
use the janitor and turn/reboot it it come to the grub cause I have dual boot
W7.
When I choose linux it goes till I see the bar that slides across but it slide slightly
and does not go into the desktop, just black.
I can install xserver-xorg and it will go to the desktop all is fine sept my touchpad
does not scroll. I tap it it will tik and untic a box. The left and right button works.
No scrolling. Can use USB mouse.
What can I do?
When I use sudo apt-get autoclean and stuff like that same thing.
It is something in the apt cashe that is doing it I know.
http://ubuntuforums.org/showthread.php?t=2192864
« Last Edit: August 11, 2015, 06:22:48 pm by ooseven »
Cevin
Peppermint 6 32 bit.
Offline ooseven
Re: Ubuntu tweak and PM 6
« Reply #1 on: August 09, 2015, 10:18:20 am »
W7.
What can I do?
Here the thing when I go to boot in to the desktop if I move my finger around
on the pad the mouse will be moving till the desktop sets in.
Cevin
« Reply #2 on: August 11, 2015, 11:06:05 am »
Does two finger scrolling work ?
Have you changed any of the settings in
menu > Preferences > Peppermint Control Center > Keyboard & Pointer (tab) > Touchpad Options
Offline ooseven
Re: Ubuntu tweak and PM 6 (Solved)
« Reply #3 on: August 11, 2015, 06:22:00 pm »
I found this page and did
xinput --set-prop 'FSPPS/2 Sentelic FingerSensingPad' 'Device Enabled' 0
in the terminal and redid the setting again it works/
Reran ubuntu tweak and it still boots up.
Cevin
Re: Ubuntu tweak and PM 6 (solved)
« Reply #4 on: August 12, 2015, 02:54:39 am »
Great stuff .. thanks for taking the time to provide your solution, and for marking the topic solved :)
