Author Topic: Bumping Up form the 3.16 LTS Kernel to the 3.19 LTS Kernel [SOLVED]  (Read 5021 times)
Online PCNetSpec
Re: Bumping Up form the 3.16 LTS Kernel to the 3.19 LTS Kernel
« Reply #30 on: August 12, 2015, 06:12:00 pm »
Which instructions did you follow to add the fan control ?
and what's the output from:
cat /etc/modprobe.d/acerhdf.conf
dmesg | grep acerhdf
« Last Edit: August 12, 2015, 06:14:26 pm by PCNetSpec »
Offline jlschwartz
  • Forum User
« Reply #31 on: August 12, 2015, 06:59:33 pm »
I followed your instructions for Peppermint 5.  Following is the output you requested:
jlschwartz@jlschwartz-AOA150 ~ $ cat /etc/modprobe.d/acerhdf.conf
options acerhdf interval=5 fanon=60000 fanoff=55000 kernelmode=1
jlschwartz@jlschwartz-AOA150 ~ $ dmesg | grep acerhdf
[   25.200410] acerhdf: module verification failed: signature and/or  required key missing - tainting kernel
[   25.244171] acerhdf: Acer Aspire One Fan driver, v.0.5.30b
Hopefully everything is ok.  Thanks for all of your help. :)
Offline jlschwartz
  • Forum User
« Reply #32 on: August 12, 2015, 07:08:57 pm »
Since my last post I did a complete shutdown and re-start of Peppermint 5 and now the fan does appear to be controlling.  Maybe it's ok.  Thanks. ;D
Online PCNetSpec
« Reply #33 on: August 13, 2015, 08:23:23 am »
Yeah that output suggests the right driver is being loaded .. so all's well :)
There's some new instructions on here somewhere for a DKMS version, but I wouldn't bother with that whilst it's working .. we can come back to that if a kernel update ever breaks the fan control (it'll never break it dangerously .. if control breaks, the fan will just be on constantly).
and as always, you're welcome :)
« Last Edit: August 13, 2015, 08:27:18 am by PCNetSpec »
Offline jlschwartz
  • Forum User
« Reply #34 on: August 13, 2015, 11:37:44 am »
perknh,
Every problem that I have is solved.  Since this is your initial post, you may want to mark it solved if you're satisfied.  Thanks. :)
« Reply #35 on: August 17, 2015, 08:20:06 am »
perknh,
That's great!  I'm glad it all worked out for you. :)
« Last Edit: August 17, 2015, 08:45:09 am by perknh »
