Author Topic: usb drive won't format  (Read 2963 times)
Offline Reg
  • Peppermint version(s): 3
« on: August 04, 2015, 08:40:00 pm »
Got this 16 gig usb drive.  It's locked into read only and will not let me alter it in any way.  Tried using the disk utility in Peppermint 3.  Got the following msgs for various attempts at clearing this thing.  Any body have any ideas on how to clear it?
When plugging in the drive
Error mounting: mount exited with exit code 18: Error opening '/dev/sdc1': Read-only file system
Failed to mount '/dev/sdc1': Read-only file system
When trying to modify the partition
Error modifying partition: helper exited with exit code 1: In part_change_partition: device_file=/dev/sdc, start=1048576, new_start=1048576, new_size=15749021696, type=0x07
Entering MS-DOS parser (offset=0, size=15750070272)
MSDOS_MAGIC found
looking at part 0 (offset 1048576, size 15749021696, type 0x07)
new part entry
looking at part 1 (offset 0, size 0, type 0x00)
new part entry
looking at part 2 (offset 0, size 0, type 0x00)
new part entry
looking at part 3 (offset 0, size 0, type 0x00)
new part entry
Exiting MS-DOS parser
MSDOS partition table detected
containing partition table scheme = 0
Warning: Unable to open /dev/sdc read-write (Read-only file system).  /dev/sdc has been opened read-only.
got it
got disk
got partition
new_size=15749021696 but resulting size, 15748562944, smaller than requested
Error: Can't have a partition outside the disk!
changed partition to start=16384 size=15749595136
Error: Can't write to /dev/sdc, because it is opened read-only.
ped_disk_commit_to_dev() failed
When trying to delete the partiton
Error erasing: helper exited with exit code 1: In part_del_partition: device_file=/dev/sdc, offset=1048576
MSDOS_MAGIC found
new part entry
new part entry
new part entry
new part entry
got it
got disk
got partition - part->type=0
Offline configX
  • Peppermint version(s): Six
Re: usb drive won't format
« Reply #1 on: August 04, 2015, 08:59:49 pm »
Have you tried creating a new partition table in GParted? I've also found sometimes that safely removing the drive and plugging it back in can cure it.
Offline Reg
« Reply #2 on: August 04, 2015, 09:25:56 pm »
Tried gparted, don't work.  Tried other versions of linux, windows and yosimite too.  Nothing will alter read only status of drive.
Offline configX
« Reply #3 on: August 04, 2015, 09:57:41 pm »
What errors do you get when running mkfs?
First determine which device and partition it is by running lsblk.
Then run:
sudo mkfs -t fat /dev/sdx1
change x to be whatever device letter you found in lsblk.
Offline Reg
« Reply #4 on: August 04, 2015, 10:13:46 pm »
typed lsblk - got sdc as the drive (only one partition)
typed sudo mkfs -t fat /dev/sdc - got - mkfs.fat: No such file or directory
it is a ntfs partiton also
« Last Edit: August 04, 2015, 10:17:25 pm by Reg »
Offline configX
« Reply #5 on: August 04, 2015, 10:16:35 pm »
Interesting, I guess Peppermint 3 didn't have dosfstools. You'll need to install that first before running mkfs.
sudo apt-get install dosfstools
Offline Reg
« Reply #6 on: August 04, 2015, 10:18:40 pm »
My bad, edited the post for reply to mkfs
Offline configX
« Reply #7 on: August 04, 2015, 10:24:37 pm »
Still seems like you're missing mkfs.fat.
What does it show when you run which mkfs.fat?
If you get nothing then I recommend trying to reinstall dosfstools.
Offline configX
« Reply #8 on: August 04, 2015, 10:26:43 pm »
Nevermind, scratch what I said - I see what happened. You didn't add 1 to the end of sdc.
Offline configX
« Reply #9 on: August 04, 2015, 10:36:27 pm »
Also, if formatting it to fat32 or ext4 doesn't work with mkfs then first try reinstalling ntfs-3g and mount the USB again.
« Reply #10 on: August 05, 2015, 12:57:05 am »
Hi Reg, I don't understand why GParted isn't working  :-\.  Have you tried this.  Insert your USB thumbdrive into your computer.  Fire up GParted
Select your thumbdrive from the dropdown list located in the top right hand section of the GParted window.
Right click on your device in main body of the GParted window.  Select unmount if necessary.
From the taskbar, select: Device
In the small advisory window, from: Select new partition table type select from the dropdown menu msdos, (this is the default setting).
Click on Apply.  Your device's image will now turn grey.
From the taskbar, select: Partition > New
In the new window, select:
  • Create as: Primary
  • File system: FAT32
  • Label: "Optional"
Click on Add.  From the toolbar, click on: Apply All Operations, (located below: Partition in the taskbar). From the small advisory window, click on: Apply.  Let GParted do its thing, click on: Close.  Exit GParted and you're done  ;).
« Last Edit: August 05, 2015, 01:16:35 am by AndyInMokum »
« Reply #11 on: August 05, 2015, 07:08:49 am »
Try running fdisk against the sig0 partition table...
Example (picked at random):  http://techspalace.blogspot.com/2011/10/solved-invalid-partition-table-on.html
« Reply #12 on: August 05, 2015, 12:55:45 pm »
If you're trying to erase the drive, AndyInMokum's suggestion (unmount / create a new partition table / create new partition) will work .. if it doesn't, the stick is likely fubar.
Offline configX
« Reply #13 on: August 05, 2015, 01:05:29 pm »
I've experienced what Reg is experiencing before and even Gparted threw errors. I assumed he already tried creating a new table based on his first few replies which is why I suggested the command line method. ntfs-3g may solve it if it wasn't included by default in Peppermint 3.
