Author Topic: After recent update the System now says Ubuntu vs. Peppermint 5 [SOLVED]  (Read 5415 times)
Re: After recent update the System now says Ubuntu vs. Peppermint 5
« Reply #15 on: July 30, 2015, 02:33:31 pm »
Hi jlschwartz,
Please open a terminal, enter the following commands and post the contents of these files:
gedit /etc/apt/sources.list
gedit /etc/apt/sources.list.d/peppermint.list
Offline jlschwartz
  • Forum User
« Reply #16 on: July 30, 2015, 02:59:59 pm »
Slim,
The first list is below.  I tried to use spoiler to condense it.
The second list is:
deb http://ppa.launchpad.net/peppermintos/release/ubuntu trusty main
deb-src http://ppa.launchpad.net/peppermintos/release/ubuntu trusty main
I hope this helps.
« Reply #17 on: July 30, 2015, 03:24:17 pm »
Are you getting any errors from:
sudo apt-get update
Offline jlschwartz
  • Forum User
« Reply #18 on: July 30, 2015, 03:37:04 pm »
No.  Not getting any errors at this time.  Several weeks back I did get errors as it indicated that I had duplicate recommended and security updates so I removed the duplicates with Synaptic.
« Reply #19 on: July 30, 2015, 04:41:11 pm »
What's the output from:
cat /etc/apt/sources.list; for X in /etc/apt/sources.list.d/*.list; do echo; echo; echo "** $X:"; echo; cat $X; done
Offline jlschwartz
  • Forum User
« Reply #20 on: July 30, 2015, 05:24:32 pm »
PCNetSpec,  Following is the output you requested:
Hope this helps.  'Thanks.
« Reply #21 on: July 31, 2015, 03:04:34 pm »
apt-cache madison base-files
Offline jlschwartz
  • Forum User
« Reply #22 on: July 31, 2015, 05:12:13 pm »
PCNetSpec,
Below is the output you requested:
jlschwartz@jlschwartz-AOA150 ~ $ apt-cache madison base-files
base-files | 7.2ubuntu5+peppermint1 | http://ppa.launchpad.net/peppermintos/release/ubuntu/ trusty/main i386 Packages
base-files | 7.2ubuntu5 | http://us.archive.ubuntu.com/ubuntu/ trusty/main i386 Packages
base-files | 7.2ubuntu5 | http://us.archive.ubuntu.com/ubuntu/ trusty/main Sources
base-files | 7.2ubuntu5+peppermint1 | http://ppa.launchpad.net/peppermintos/release/ubuntu/ trusty/main Sources
I hope this helps.  Thanks.
« Reply #23 on: August 01, 2015, 05:07:26 am »
OK, for some reason your system has downloaded the new Ubuntu version of base-files (7.2ubuntu5.2) which is the new version for the 14.04.2 release .. it should NOT have done that as packages from the Peppermint PPA should take priority  :-\
Anyway .. to fix it run these commands in sequence:
sudo apt-get install base-files=7.2ubuntu5+peppermint1now check you have version 7.2ubuntu5+peppermint1 installed by running:
dpkg -l | grep base-filesand if it mentions 7.2ubuntu5+peppermint1 as the version .. check:
cat /etc/lsb-releasereads:
DISTRIB_ID=Peppermint
DISTRIB_RELEASE=5
DISTRIB_CODENAME=trusty
DISTRIB_DESCRIPTION="Peppermint Five"
if it does, run:
sudo update-grubthen just to be sure it doesn't happen again, lets put a hold on that package:
sudo echo "base-files hold" | sudo dpkg --set-selectionsnow test the GRUB menu and inxi read correctly
Is anyone else running Peppermint 5 getting this same problem ?
If everyone else running Peppermint 5 is having this same problem, I'll update the version number of the base-files package in our Peppermint 5 PPA so the fix will come via an update.
Offline jlschwartz
  • Forum User
« Reply #24 on: August 01, 2015, 08:24:39 am »
It worked!  I'm back to Peppermint.  See below:
jlschwartz@jlschwartz-AOA150 ~ $ dpkg -l | grep base-files
hi  base-files                                                  7.2ubuntu5+peppermint1                                      i386         Debian base system miscellaneous files
Grub shows Peppermint too.  Thank you very much for all of your help.  ;D
Re: After recent update the System now says Ubuntu vs. Peppermint 5 [SOLVED]
« Reply #25 on: August 01, 2015, 08:47:00 am »
You're most welcome :)
« Reply #26 on: August 01, 2015, 01:15:04 pm »
Hi PCNetSpec,
I'm running Peppermint Five on one machine that is updated with synaptic very regularly -- today I did the last update -- and I do NOT have this problem. My base-files and the output from cat /etc/lsb-release are normal.
« Reply #27 on: August 01, 2015, 01:31:26 pm »
scifidude's VM install also seems to suggest this was a one off hiccup but I thought I'd better ask.
Cheers Slim.Fatz :)
« Reply #28 on: August 01, 2015, 01:41:14 pm »
Cheerio, PCNetSpec  ;D
