Author Topic: After recent update the System now says Ubuntu vs. Peppermint 5 [SOLVED]  (Read 4821 times)
Offline jlschwartz
  • Forum User
I ran an a software update today and noticed that the grub menu says Ubuntu now instead of Peppermint as the first item.  Also, the system returns the following:
inxi -F
System:    Host: jlschwartz-AOA150 Kernel: 3.13.0-61-generic i686 (32 bit) Desktop: N/A Distro: Ubuntu 14.04 trusty
Machine:   System: Acer (portable) product: AOA150 version: 1
           Mobo: Acer model: N/A Bios: Acer version: v0.3301 date: 05/09/2008
CPU:       Single core Intel Atom CPU N270 (-HT-) cache: 512 KB flags: (nx pae sse sse2 sse3 ssse3)
           Clock Speeds: 1: 1600.00 MHz 2: 1600.00 MHz
Graphics:  Card: Intel Mobile 945GSE Express Integrated Graphics Controller
           X.Org: 1.15.1 drivers: intel (unloaded: fbdev,vesa) Resolution: 1024x600@60.0hz
           GLX Renderer: Mesa DRI Intel 945GME x86/MMX/SSE2 GLX Version: 1.4 Mesa 10.1.3
Audio:     Card: Intel NM10/ICH7 Family High Definition Audio Controller driver: snd_hda_intel
           Sound: Advanced Linux Sound Architecture ver: k3.13.0-61-generic
Network:   Card-1: Realtek RTL8101E/RTL8102E PCI Express Fast Ethernet controller driver: r8169
           IF: eth0 state: down mac: 00:1e:68:f4:19:93
           Card-2: Qualcomm Atheros AR242x / AR542x Wireless Network Adapter (PCI-Express) driver: ath5k
           IF: wlan0 state: up mac: 00:23:4d:6e:1c:8a
Drives:    HDD Total Size: 160.0GB (13.0% used) 1: id: /dev/sda model: WDC_WD1600BEVT size: 160.0GB
Partition: ID: / size: 42G used: 20G (49%) fs: ext4 ID: swap-1 size: 1.06GB used: 0.00GB (0%) fs: swap
Sensors:   System Temperatures: cpu: 71.0C mobo: N/A
Info:      Processes: 130 Uptime: 15 min Memory: 552.2/988.7MB Client: Shell (bash) inxi: 1.9.17
Did the update to Peppermeint 5 do something wrong?  What should I do to fix this?  Thanks.
« Last Edit: August 01, 2015, 11:27:05 am by jlschwartz »
Re: After recent update the System now says Ubuntu vs. Peppermint 5
« Reply #1 on: July 29, 2015, 11:15:27 pm »
I could be wrong, but I don't think Team Peppermint is still releasing updates for Peppermint 5.  So, you probably downloaded some updates from the official Ubuntu repos for the LTS release that overwrote something that was set by Peppermint.  I wouldn't worry too much about it.  After all, Peppermint 5 is technically Ubuntu, just with a different desktop environment and some other changes.  ;)  Any OS based on Ubuntu's source code is still Ubuntu underneath.
Now, if it said "Fedora," I'd worry.   :o
« Reply #2 on: July 29, 2015, 11:24:10 pm »
I'm going to do a test install of P5 on VirtualBox, update it and see if I get the same thing.
« Reply #3 on: July 30, 2015, 12:00:50 am »
Well, I did a test install in VirtualBox and updated and it still says "Peppermint Five" when I run inxi -F.  I honestly don't know how or why yours says "Ubuntu."   ???  Though, I'm running 64-bit, not 32-bit, so I don't know if that makes a difference.
« Reply #4 on: July 30, 2015, 04:17:46 am »
inxi gets its "Distro" info from "/etc/issue"
but
GRUB gets the distro name from "/etc/lsb-release"
both are contained in the "base-files" package, so I can only assume that for some reason your system downloaded the Ubuntu version of "base-files"
can you post the output from:
dpkg -l | grep base-files
Offline jlschwartz
  • Forum User
« Reply #5 on: July 30, 2015, 09:38:45 am »
I don't know how that could have happened.  As you requested, see below:
$ dpkg -l | grep base-files
ii  base-files                                                  7.2ubuntu5.2                                                i386         Debian base system miscellaneous files
Not sure why it is so jumbled looking.  Any help you could give would be appreciated.  Thanks.
« Reply #6 on: July 30, 2015, 10:33:08 am »
Hi jlschwartz,
It actually looks quite normal. Mine looks like this:
ii  base-files                           7.2ubuntu5.2+peppermint2         i386    Debian base system miscellaneous files
Yours is just missing the "+peppermint2" part.
Offline jlschwartz
  • Forum User
« Reply #7 on: July 30, 2015, 10:38:24 am »
It's just unnerving for me to see Ubuntu and not Peppermint in Grub and the system info.  I can't figure out what could have caused this.  Hopefully, I can fix it.  Thanks.
« Reply #8 on: July 30, 2015, 12:02:03 pm »
Did you by chance at any time remove the peppermint system packages?
Offline jlschwartz
  • Forum User
« Reply #9 on: July 30, 2015, 12:23:39 pm »
I didn't remove anything knowingly.  The system said updates were available and I installed them and when I rebooted after that it was this way.  If I did something, I didn't know it.  Thanks.
« Reply #10 on: July 30, 2015, 12:29:06 pm »
I'm sure you didn't, I was just grasping at straws.   :-\
Offline jlschwartz
  • Forum User
« Reply #11 on: July 30, 2015, 03:50:54 pm »
Slim, thanks for your reply.  I hope I get that Peppermint part back.
« Reply #12 on: July 30, 2015, 04:25:34 pm »
Hi jlschwartz,
You're welcome. As long as everything is working without any hiccups and nothing seems to be missing, then I don't think that you should worry about this. Think of it more as  "behind the scenes cosmetic blemish"   :P
« Last Edit: July 30, 2015, 04:52:41 pm by Slim.Fatz »
« Reply #13 on: July 30, 2015, 04:30:02 pm »
If you run:
sudo apt-get update
sudo apt-get install --reinstall base-files
now what's the output from:
dpkg -l | grep peppermint
Offline jlschwartz
  • Forum User
« Reply #14 on: July 30, 2015, 05:06:55 pm »
PCNetSpec,
I tried what you asked and got the following:
$ sudo apt-get install --reinstall base-files
Reading package lists... Done
Building dependency tree
Reinstallation of base-files is not possible, it cannot be downloaded.
0 upgraded, 0 newly installed, 0 to remove and 4 not upgraded.
Also, if I go to repositories in Synaptic the first one now says Ubuntu instead of Peppermint.  Maybe that's why it cannot download the base files? :-\
