Author Topic: Question about old forum "Is this the answer to my usb wifi"? (Solved)  (Read 2037 times)
Offline chesterton
  • Peppermint version(s): Peppermint 4
Hi,
I am unable to find this old topic on this new forum, so I'll start a new thread here. I apologize if that's not the correct process.
I am converting two old Toshiba notebook computers from XP to Peppermint. I am using one to try out the steps for the other one (my mother-in-laws). Since she's still using hers, I wanted to limit the downtime. Anyway, for the trial PC, I found that the TP-LINK TL-WN725N wireless USB that I'm going to use for my mother-in-law's machine required some changes to Peppermint that are explained well in the old forum topic "Is this the answer to my usb wifi problem?". Everything went smoothly when I tried out the changes to the trial PC.
But when I tried the same steps on my mother-in-law's laptop, I got an error. All looked good until this step:
cd ~/RTL8188EU/rtl8188eu
make
When I did the make, I got this error:
make: *** /lib/modules/3.8.0-33-generic/build: No such file or directory.  Stop.
make: *** [modules] Error 2
I didn't get this error on the trial machine.
I checked both of the computers, and neither have a file or directory called "/lib/modules/3.8.0-33-generic/build".
Thanks in advance for any help.
« Last Edit: April 24, 2014, 04:03:38 pm by chesterton »
Re: Question about old forum "Is this the answer to my usb wifi"?
« Reply #1 on: April 24, 2014, 11:21:47 am »
Connect the PC to  your router with an ethernet cable .. then open a terminal and run:
sudo apt-get updatethen
sudo apt-get upgradethen
sudo apt-get dist-upgradethen REBOOT
Once rebooted, run:
sudo apt-get install linux-headers-generic build-essentialNow follow the original instructions again.
Offline chesterton
« Reply #2 on: April 24, 2014, 04:02:23 pm »
That got it! Wifi's up and working. Thanks so much!
You're welcome .. thanks for marking the topic solved :)
