Author Topic: Grub problem after install PM6  (Read 5284 times)
Offline puls
    • Puls Kosmosu
  • Peppermint version(s): Peppermint Six
« on: July 12, 2015, 12:33:51 am »
Hi,
I am totally new to Peppermint Linux.
I need some help fixing the installation.
I downloaded the iso file, made a bootable USB with Unetbootin and installed the PM6 on my netbook choosing the option to wipe the disk of the previous system and install PM on whole the disk. It all went smoothly.
However, after the installation when I removed my USB stick and turned on the computer it goes into
GNU GRUB version 2.02~beta2-9ubuntu1.3
Minimal BASH-like line editing is supported. for the first word, TAB lists possible command completions. Anywhere else TAB lists possible device or file completions.
....and stops there.
Using some of the tricks I could find on the internet I found out that I can launch PM6 writing at the grub line:
grub> set  pager=1
grub> set root=(hd0,2)
grub> linux /boot/vmlinuz-3.16.0-37-generic root=/dev/sda2
grub> initrd /boot/initrd.img-3.16.0-37-generic
grub> boot
and it does work every time. But how do i do that automatic? It just sounds ridiculous to do that every time.
Thanks
Re: Grub problem after install PM6
« Reply #1 on: July 12, 2015, 01:22:36 am »
Is this a UEFI dual boot configuration ?
and can you post the output from:
sudo fdisk -l
Have you tried simply booting the way you mentioned above, then in the running system opening a terminal and running:
sudo grub-install /dev/sda?
« Last Edit: July 12, 2015, 01:29:53 am by PCNetSpec »
Offline puls
    • Puls Kosmosu
« Reply #2 on: July 12, 2015, 01:31:25 am »
Hey,
yes - it is a rather new netbook (HP Pavilion 10.1 TouchScreen) but i used to install numerous linux distributions like kubuntu on it and it ran with no problem.
Not sure if that would be a doubleboot as during the installation i chose to erase the disk and install the system on whole disk.
The other thing:
as you said - returned: No errors found.
But it still stops at grub line during launching the computer
« Last Edit: July 12, 2015, 01:34:25 am by puls »
« Reply #3 on: July 12, 2015, 01:34:50 am »
Can you open a terminal and run:
sudo fdisk -lthen post back here what was returned in the terminal.
Offline puls
    • Puls Kosmosu
« Reply #4 on: July 12, 2015, 01:35:44 am »
the picture above is what shows after sudo fdisk -l
or simply click here
https://www.dropbox.com/s/ttpnt813614b7fs/wp_20150712_10_26_27_pro.jpg?dl=0
« Last Edit: July 12, 2015, 01:52:38 am by puls »
« Reply #5 on: July 12, 2015, 01:54:40 am »
The image you posted above doesn't display for anyone other than you .. you need to be logged onto your dropbox account for it to display.
Either put it in the "Public" folder on dropbox, then provide the link between IMG tags
or host it on IMGUR:
http://imgur.com/
then post the IMG link
That said, images aren't searchable, so it would be better if you just copied the text from the terminal and pasted it into your next posting between CODE tags
« Last Edit: July 12, 2015, 01:56:40 am by PCNetSpec »
Offline puls
    • Puls Kosmosu
« Reply #6 on: July 12, 2015, 02:01:02 am »
WARNING: GPT (Guid Partition Table) detected on '/dev/sda'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/sda" 500.1 GB, 500107862016 bytes
255 heads, 63 sectors/track, 60801 cylinders, total 976773168 sectors
I/O size (minimum/optimal): 4096 bytes /4096 bytes
Disk identifier: 0x000000000
Device     Boot       Start          End           Blocks        Id       System
/dev/sda1                       1  976773167    488386583+   ee         GPT
« Reply #7 on: July 12, 2015, 02:02:33 am »
It seems you have a GPT partition table, are you game for formatting the HDD with an msdos style partition table (which will erase the drive as a consequence) then reinstalling Peppermint ?
Offline puls
    • Puls Kosmosu
« Reply #8 on: July 12, 2015, 02:05:01 am »
Absolutely yes. There is basically nothing on that computer anyway. If you just told me how to do that - I will be more than happy to do that
« Reply #9 on: July 12, 2015, 02:19:39 am »
OK, boot to a Peppermint LiiveCD/LiveUSB
once at the Live session desktop, fire up GParted
menu > System Tools > GParted
in GParted, make sure  /dev/sda is selected on the right of the toolbar.
then select
Device > Create Partition Table...
when prompted select "msdos style parttion table" and continue
once done, close GParted, then run the Peppermint installer from the desktop icon.
Note:-
When you select Device > Create Partition Table... you may be told GParted cannot continue because a partition is currently in use .. in that case, one at a time right-click on the partitions in the list and select "Unmount" (or Swapoff" in the case of the linux-swap partition), then try Device > Create Partition Table... again.
Offline puls
    • Puls Kosmosu
« Reply #10 on: July 12, 2015, 02:22:32 am »
Ok, but to clarify, by "boot to LiveUSB" you mean :
-boot from USB
-choose try Peppermint Linux without installing
-and then follow your instructions?
« Reply #11 on: July 12, 2015, 03:14:01 am »
Boot from the LiveUSB stick or LiveCD you created earlier (whatever you used for the earlier installation) and select "Try Peppermint"
Offline puls
    • Puls Kosmosu
« Reply #12 on: July 12, 2015, 03:17:41 am »
Did all of the above. Just finished installing. Resetted the computer and it finished.... at grub line again.  :(
The funny thing is that fdisk states a GPT partition again. Somehow it did not change it to msdos
« Last Edit: July 12, 2015, 03:19:40 am by puls »
« Reply #13 on: July 12, 2015, 03:23:38 am »
You could try using boot-repair:
http://help.ubuntu.com/community/Boot-Repair
« Reply #14 on: July 12, 2015, 03:29:03 am »
Hi puls,
Also, when you did the LiveUSB reformat of the HDD to msdos using GParted, did you remember to apply the change and actually reformat the HDD? Did the process itself then return any error messages?
