Author Topic: Peppermint6 Malformed File? [Unresolved Bug]  (Read 1168 times)
Offline momist
  • Peppermint version(s): 4
« on: July 04, 2015, 03:57:43 pm »
Hi everyone,
I've just installed Peppermint 6 as a clean install on my Dell Latitude D630.  All went well, then after booting into the new system, it offered me a bunch of updates including the new kernel 3.16.0-41
After it had finished, I rebooted, and just to make sure I did sudo update-grub.
I now get the following notice on every boot
 error: malformed file
press any key to continue
If I leave this to time out, it boots normally anyway, or it will do if I press a key.
Any ideas what's going on here please?  Thanks.
« Last Edit: July 04, 2015, 05:13:41 pm by AndyInMokum »
  • Peppermint version(s): PM 9 & PM 8 Respin-2 (64-bit)
Re: Peppermint6 Malformed File?
« Reply #1 on: July 04, 2015, 04:20:39 pm »
Hi momist, this is a known GRUB2 bug.  There doesn't appear to be a workaround yet: https://bugs.launchpad.net/ubuntu/+source/grub2/+bug/1311247.  Someone may have seen something else that may help - good luck  ;).
Offline momist
« Reply #2 on: July 04, 2015, 04:25:47 pm »
Thanks AndyInMokum, if it's a known bug that's good enough for me, I'll just ignore it. 8)
Re: [Done] Peppermint6 Malformed File?
« Reply #3 on: July 04, 2015, 04:37:57 pm »
I've just installed Peppermint 6 as a clean install on my Dell Latitude D630 [...]
Another Dell Latitude D630 user...
We should start our own user group.   :D
