Author Topic: Peppermint 6 - How to add Home/Computer/Network/Trash icons to the desktop  (Read 9906 times)
The following tutorial is for Peppermint Six ONLY, it will NOT work in earlier versions of Peppermint
Now that Peppermint 6 has switched to the Nemo file manager (which also controls the desktop), it's easy to display any of the following icons on your desktop
Home
Computer
Network
Trash
Like the top 4 icons in this image
(click image to enlarge)
OK, let's do it....
First we need to install dconf-editor, so open a terminal (Ctrl+Alt+T) and run:
sudo apt-get install dconf-editorNow in the system menu fire up:-
menu > System Tools > dconf Editor
then in the left hand column of the dconf Editor window, navigate to the schema:-
org > nemo > desktop
now in the right hand column you'll have options to add ticks to the boxes
computer-icon-visible
home-icon-visible
network-icon-visible
trash-icon-visible
there's also an option for "volumes-visible" which will display icons for mounted volumes (CD/DVD's/SDcards/USB sticks/mounted network shares/etc.) on your desktop if you want.
Have fun, but be careful what you change in dconf-Editor  .. if you don't understand what a particular key does, probably best to leave it alone ;)
« Last Edit: June 17, 2015, 07:45:17 am by PCNetSpec »
