Author Topic: GRUB fails to install  (Read 6855 times)
Offline Karthikeyan
  • Peppermint version(s): 6
« on: June 12, 2015, 08:52:27 am »
I was installing the latest Peppermint OS 6 side by side of Windows 8. At the end when the GRUB was about to be installed, a failure message was saying "grub-efi-amd64-signed failed to install into /target/". Without GRUB I couldn't boot into POS6.
I enabled secure boot and entered peppermint and ended up in this screen!
Ask for any missing details, I will provide. Please help to resolve this issue.
PS:My problem is very similar to http://forum.peppermintos.com/index.php/topic,1904.0.html, but the user didnt mention GRUB installation failure nor could I understand the solution provided. Please help.
« Last Edit: June 12, 2015, 10:55:00 am by Karthikeyan »
Re: GRUB fails to install
« Reply #1 on: June 12, 2015, 09:43:28 am »
Can you boot to the LiveCD/LiveUSB, open a terminal (Ctrl+Alt+T)  and post the output from running this command:
sudo fdisk -l
Offline Karthikeyan
« Reply #2 on: June 12, 2015, 10:20:10 am »
peppermint@peppermint ~ $ sudo fdisk -l
Disk /dev/sda: 500.1 GB, 500107862016 bytes
255 heads, 63 sectors/track, 60801 cylinders, total 976773168 sectors
Disk identifier: 0xccdc05c2
/dev/sda1               1   976773167   488386583+  ee  GPT
Partition 1 does not start on physical sector boundary.
Disk /dev/sdb: 16.0 GB, 16008609792 bytes
255 heads, 63 sectors/track, 1946 cylinders, total 31266816 sectors
Disk identifier: 0x00000000
/dev/sdb1   *        2048    31266815    15632384    c  W95 FAT32 (LBA)
« Last Edit: June 15, 2015, 12:59:04 am by Karthikeyan »
« Reply #3 on: June 12, 2015, 10:34:16 am »
Is there anything on the 500GB HDD that you need to keep .. or can it be completely formatted ?
Offline Karthikeyan
« Reply #4 on: June 12, 2015, 10:53:47 am »
Oh I forgot the most important...I am installing along side Windows 8.
« Reply #5 on: June 12, 2015, 11:29:42 am »
I take it Windows is preinstalled and you don't have the installation media ?
Offline Karthikeyan
« Reply #6 on: June 12, 2015, 11:48:52 am »
Installation media of what? I dont know what an installation media is in the first place... ;)
« Reply #7 on: June 12, 2015, 11:52:17 am »
media = disk or whatever media the installation came on
usually a DVD, but could be a USB stick
So do you have the installation media for reinstalling Win 8 ?
Offline Karthikeyan
« Reply #8 on: June 12, 2015, 12:03:52 pm »
No not a media for reinstalling Windows 8. Does a recovery drive count as a installation media? Because I have one. And are you hinting at erasing Windows and reinstalling it?!  :o
« Reply #9 on: June 12, 2015, 01:08:35 pm »
Formatting the drive away from a GPT partition table and reinstalling Windows 8 in legacy BIOS mode would certainly have been the easiest option if it were possible.
let's have a look at your GPT disks structure
can you boot to the LiveCD/LiveUSB .. connect to the internet, and install gdisk:
sudo apt-get install gdiskthen post back here the output from:
sudo gdisk -l /dev/sdaand
uname -a
Offline Karthikeyan
« Reply #10 on: June 14, 2015, 11:06:55 pm »
peppermint@peppermint ~ $ sudo gdisk -l /dev/sda
GPT fdisk (gdisk) version 0.8.8
Partition table scan:
  MBR: protective
  BSD: not present
  APM: not present
  GPT: present
Found valid GPT with protective MBR; using GPT.
Disk /dev/sda: 976773168 sectors, 465.8 GiB
Logical sector size: 512 bytes
Disk identifier (GUID): 821999CF-D919-48BE-882E-CBC745DD0107
Partition table holds up to 128 entries
First usable sector is 34, last usable sector is 976773134
Partitions will be aligned on 2048-sector boundaries
Total free space is 3106 sectors (1.5 MiB)
Number  Start (sector)    End (sector)  Size       Code  Name
   1            2048          821247   400.0 MiB   2700  Basic data partition
   2          821248         1435647   300.0 MiB   EF00  EFI system partition
   3         1435648         1697791   128.0 MiB   0C01  Microsoft reserved part
   4         1697792       579235029   275.4 GiB   0700  Basic data partition
   5       740642816       937623284   93.9 GiB    0700  Basic data partition
   6       945442816       946364415   450.0 MiB   2700
   7       946364416       976773119   14.5 GiB    2700  Basic data partition
   8       937623552       945442815   3.7 GiB     8200
   9       579235840       740642815   77.0 GiB    0700
peppermint@peppermint ~ $ uname -a
Linux peppermint 3.16.0-37-generic #51~14.04.1-Ubuntu SMP Wed May 6 15:23:14 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
« Last Edit: June 14, 2015, 11:23:47 pm by AndyInMokum »
« Reply #11 on: June 14, 2015, 11:30:40 pm »
Hi Karthikeyan, how's it going?  For future reference could you please encapsulate terminal outputs with the # code function.  It preserves the original format.  This function is located above the :-[ Embarrassed emoticon in the forum editor.  I've done this for you this time  - many thanks  ;)!
« Reply #12 on: June 15, 2015, 08:29:13 am »
I don't think there's any SAFE way to do this (but I'm still reading).
If the machine won't install Peppermint 6 64bit in EUFI mode, then to install GRUB on a drive with a GPT partition table requires an EF02 bios_boot partition to be present on the drive.
I'm unsure how to achieve this without destroying Windows or Windows EFI booting .. or if the bios_boot partition can go anywhere as long as it's flagged correctly.
I'm trying to figure it out.
Did you try installing the 64bit version in UEFI mode ?
(ie. NOT in legacy BIOS mode, but with secureboot disabled)
Are you able to boot a Peppermint 6 64bit LiveCD/LiveUSB in UEFI mode (with secure boot disable) ?
If so, have you tried running boot-repair:
https://help.ubuntu.com/community/Boot-Repair
whilst in UEFI mode (with secure boot disabled) ?
« Last Edit: June 15, 2015, 08:47:42 am by PCNetSpec »
Offline Karthikeyan
« Reply #13 on: June 15, 2015, 09:13:30 am »
Yes installed the 64 bit Perppermint OS 6 in UEFI mode.
Yes can boot a LiveUSB without secure boot.
Currently running codes from the Boot Repair link you gave. Will update some time
« Reply #14 on: June 15, 2015, 09:18:00 am »
Please do let us know if Boot-Repair helps.
