Author Topic: Peppermix Dark + Orange Ultra Flat Icons = very nice IMO  (Read 2306 times)
Offline mattosensei
  • Linux with 'L' plates
  • Peppermint version(s): 6
« on: June 06, 2015, 08:49:52 am »
Can I recommend Peppermix Dark theme + Ultra Flat Icons?
To do this you need to:
Menu > Preferences > Customize Look & Feel > Widget - now choose Peppermix Dark Theme
Open a terminal (CTRL+ALT+T) then put in:
sudo add-apt-repository ppa:noobslab/icons
sudo apt-get update
Choose your colour scheme to install:
Orange:
sudo apt-get install ultra-flat-icons-orange
Green:
sudo apt-get install ultra-flat-icons-green
Blue:
Now go  to:
Menu > Preferences > Customize Look & Feel > Icon theme - choose Ultra Flat Icons.
Enjoy!
Info originally found here.
PS note that if you install more than 1 colour you may get an issue where they have the same name in the Customise Look and Feel options dialogue. If that happens look here for advice on how to fix.
