Author Topic: Slackware  (Read 8761 times)
Offline 10i
  • Peppermint Enthusiast
    • My Peppermint Blog
Slackware
« on: April 16, 2014, 04:18:27 pm »
Hi everyone, I really enjoy Peppermint Linux. I am looking for a new challenge, been considering Slackware, although I might be in too deep here.
1. Does anyone here have slackware experience?
2. My computer is set up, I have my networking settings configured, printer is installed, etc. etc. Is there a challenge I can undertake to learn more about Linux - without changing the distro I am using?
Sent from my IdeaTab A3000-H using Tapatalk
Offline mac
Re: Slackware
« Reply #1 on: April 16, 2014, 04:27:22 pm »
Start with the man pages.  Open a terminal and type ...
man sudo
Then try
man lspci
...and so forth and so on with just about any linux command or program you want to learn about.
Post back when you've mastered all of that!  :D
Just kidding, but that should keep you busy for a while.
As far as distros......try Arch Linux.  There is a great deal of online help with that one.  You can also
try Debian.  Have fun!   ;)
Reg. Linux User #432835
Offline 10i
Re: Slackware
« Reply #2 on: April 16, 2014, 04:28:51 pm »
I am sure I should be able to learn more about Linux, without having to do something as drastic as changing distro's.
I've been using Peppermint since ICE, and I feel that I don't want to turn my back on my faithful friend.
Offline mac
Re: Slackware
« Reply #3 on: April 16, 2014, 04:32:18 pm »
... I am looking for a new challenge, been considering Slackware...
Offline 10i
Re: Slackware
« Reply #4 on: April 16, 2014, 04:33:12 pm »
man sudo
Then try
man lspci
Thanks, you can check http://bropages.org , heard about it on the Linux for the rest of us podcast.
The problem with typing man Ispci, etc. Is that I don't know very many Linux commands, other than sudo apt-get install and sudo apt-get remove.
I know how to use Linux for desktop use, but I really don't know much of what is going on in the background. Not sure how to start learning that.
Offline mac
Re: Slackware
« Reply #5 on: April 16, 2014, 05:01:31 pm »
HERE is a list of commands you can work through, if you'd like.  Don't actually run the commands (unless you know what they do) but you can use the manpages to learn about them.
For bropages....Assuming you're running Peppermint 4...
Install rubygems....
sudo apt install rubygems
Then, install bropages....
sudo gem install bropages
To use it type bro and then the command you're interested in.  For example....
bro lspci
Edit: Look HERE
Also, check out Youtube for Linux video how to's.
Above all, read the Peppermint Forums religiously and ask questions as you like.
« Last Edit: April 16, 2014, 05:09:58 pm by mac »
Re: Slackware
« Reply #6 on: April 16, 2014, 05:03:53 pm »
Maybe you should try Porteus 3.  It is based on Slackware but designed to be used from USB stick. That way you can keep your Peppermint OS on your computer.  Porteus is stupid quick because it runs off your RAM.  They have a build center where you can custom build your ISO.  A little bit like OpenSuse has.  It is really very cool.   I've got Porteus 2.1 Maté 64bit on an !6GB SanDisk thumb drive. My Porteus Desktop. It absolutely flies.  Being Slackware based does mean It takes a little getting used to but once the penny drops, it is really easy.   Their forums are very friendly and helpful too.  Does that sound famiiar  ;D?  Porteus 3 has only just been released, it might be just what you are looking for.  http://www.porteus.org/.
Offline mac
Re: Slackware
« Reply #7 on: April 16, 2014, 05:21:15 pm »
 @10i
manpages provide a lot more info and depth than do the bropages
Either way, enjoy your pursuit!  8)
Offline 10i
Re: Slackware
« Reply #8 on: April 17, 2014, 07:42:16 am »
Thanks guys, I now have somewhere to begin. Will check out the links.
Thanks everyone for your encouragement so far :)
Offline mac
Re: Slackware
« Reply #9 on: April 17, 2014, 07:52:53 am »
You're welcome!
Did you try bropages?
Offline 10i
Re: Slackware
« Reply #10 on: April 17, 2014, 11:40:10 am »
You're welcome!
Hi mac, I spent the afternoon getting Porteus working on a flash drive. I really battled, first with the SD card (my netbook refuses to boot from SD cards), then I found a flash drive. The tutorial somehow did not work that I found on the site (they mention using the terminal, I had to use the GUI to get where I needed to be and used Furious ISO mount as the commands they mentioned did not work on my system).
Making a long story short, I still love Peppermint and the way it does things. Somehow I always battle when having to follow tutorials: stuff written for slackware "somehow" does not work in Porteus... and so on and so forth.
If I can't find a "Slackware for Dummies" book somewhere, I might not make it  :o
Offline mac
Re: Slackware
« Reply #11 on: April 17, 2014, 02:03:48 pm »
Try THIS and THIS  :)
EDIT:  BTW, there is a book, "Slackware Linux for Dummies" on both Amazon and Goodreads.
« Last Edit: April 17, 2014, 02:09:59 pm by mac »
Offline 10i
Re: Slackware
« Reply #12 on: April 17, 2014, 02:28:37 pm »
You're welcome!
Looking at it now :)
Re: Slackware
« Reply #13 on: April 17, 2014, 02:30:27 pm »
I once had an idea for a Gentoo based distro where you had to compile everything on a black screen with black text and highlighting
Well you know the way Gentoo users like everything to be as hard as possible.....
S&M Linux - "Be gentoo with me" edition
Maybe this would be an interesting project ?
Oh, and no books allowed .. Mwuhahaha ;)
I also considered removing the lettering from the keys, and using a foreign keyboard layout .. but figured that was probably a bit over the top  :o
« Last Edit: April 17, 2014, 02:34:08 pm by PCNetSpec »
Offline 10i
Re: Slackware
« Reply #14 on: April 17, 2014, 02:52:16 pm »
I think I am going to learn more about Debian first. I saw the book on Amazon, they don't ship to my country because our postal service is unreliable (last time I checked).
