Author Topic: Black screen after booting [SOLVED]  (Read 5983 times)
Re: Black screen after booting
« Reply #15 on: April 20, 2015, 02:06:20 am »
That's what I was asking .. is the /home partition new, or does it contain stuff from a previous Linux installation ?
And can we have a recap .. are you at the position where you can log on, but all you can see is the wallpaper ?
What happens if you drop to a console with Ctrl+Alt+F3, log on in text mode, then run:
sudo service lightdm restart?
Offline eltrenveloz
  • Peppermint version(s): 5
« Reply #16 on: April 20, 2015, 08:33:50 am »
No, I didn't format the /home partition. I keep it with my personal stuff so I can change OS without losind them. So, yes, it keeps information from previous Linux installation.
As a guest user, I can log in and use the computer just fine. When I log in with my user, all I see is the wallpaper and no menu panel.
« Last Edit: April 20, 2015, 09:08:20 am by eltrenveloz »
Offline eltrenveloz
« Reply #17 on: April 20, 2015, 09:07:17 am »
I did this when I was logged in with my user. It restarted but just the same (wallpaper, but no menu panel)
« Reply #18 on: April 20, 2015, 11:03:53 am »
If you kept your home folder from a previous Linux distro, half your config files will be wrong because they're hidden in your home folder.
Create a new user from the command line .. then copy your user files from the old user.
Offline eltrenveloz
Re: [SOLVED] Black screen after booting
« Reply #19 on: April 21, 2015, 07:05:33 pm »
I tried creating a new user but it didn't work, still the same bug. So, I saved my files, formatted the whole disk and did a clean installation. Everything's working just fine :) Than you all for your help (and patience...). PM5 looks great!
« Last Edit: April 21, 2015, 07:15:22 pm by eltrenveloz »
« Reply #20 on: April 21, 2015, 11:08:12 pm »
...... Everything's working just fine :) Than you all for your help (and patience...). PM5 looks great!
Hi eltrenveloz, this is great news  ;).  I'm really happy you've found a solution - outstanding!  Many thanks for marking the topic as, [SOLVED]  8)!!
Re: Black screen after booting [SOLVED]
« Reply #21 on: April 22, 2015, 04:39:23 pm »
Hi eltrenveloz, this is great news  ;).  I'm really happy you've found a solution - outstanding!  8)!!
Hello eltrenveloz,
This is really terrific news.  I can't say it any better than AndyInMokum himself:  This is outstanding!
I'm happy to see this all worked out for you!  :)
perknh
