Author Topic: (SOLVED) Install Printer with T23 ,Pmint 3  (Read 4951 times)
bobww99
  • Guest
« on: April 15, 2014, 08:59:49 pm »
Computer: Thinkpad T23
Printer:  Brother HL 2270DW as describe in Brothers Quick Set Up Guide. The actual label on the printer says that it is mod.HL 22 ? Might be a general family of printers of which 2270 is a member?
Would like to:
Connected/configured my printer within peppermint 3 from a lan wired router with printer connected through the same router.
One of the clearest instructions/ (but too advanced for me) references I could find was:
http://community.linuxmint.com/tutorial/view/1200
http://community.linuxmint.com/tutorial/view/194
Note: This T23 is Lan wired to the same router that this printer is connected to.
            I have a (bloat ware) Brother installation disk that is designed for Windows and Mac installation.I would like to stay     away from this disk hairball.
Hope the above will help.
Thank You,
Bob
« Last Edit: May 01, 2014, 08:45:45 am by bobww99 »
Re: Install Printer with T23 ,Pmint 3
« Reply #1 on: April 15, 2014, 10:54:45 pm »
Hi Bob
You may need an extra driver package for that printer so open synaptic package manager and look for brother-cups wrapper-laser and install it
or open terminal type the following
if this is a wireless printer is it already connected to the network ?
if so open the terminal and type
sudo apt-get install brother-cups-wrapper-laser, then system-config-printer
The "Add Printer" dialogue box should open select "Add +" another box will open up if your see you printer listed click on it and select "> Forward"
the next box should show a list of manufacturers, select Brother then > Forward, when the next box opens look for your printer model select it then
"> Forward again and hopefully your printers installed and ask you if you want to do a test print select "Yes to test.
If you don't see your printer listed in Add Printer dialogue Box stop and post back here
Good luck
« Last Edit: April 16, 2014, 11:06:59 am by emegra »
bobww99
  • Guest
« Reply #2 on: April 16, 2014, 09:23:40 am »
Hi Graeme or any guru who wants to help out? (feel free),
I have a wireless* capability, however, I am connected thru a wired Lan to a at&t router which is inturn, has the Brother 2270DW connected to the same at&t router (home network).
1)From terminal:
_______________________________________________________________________________________________________________
bob@bob-laptop ~ $ sudo apt-get install brother-cups-wrapper-laser,
[sudo] password for bob:
Reading package lists... Done
Building dependency tree
E: Unable to locate package brother-cups-wrapper-laser,
bob@bob-laptop ~ $ system-config-printer
WARNING: gnome-keyring:: couldn't connect to: /tmp/keyring-638Hee/pkcs11: No such file or directory
No ID match for device parallel:/dev/lp0:
MFG:unknown;MDL:;
bob@bob-laptop ~ $
From your instructions:"If you don't see your printer listed in Add Printer dialogue Box stop and post back here"
 I don't see my printer listed?  (**for attached screenshot) ---No HL 22xx series (relative new Brother printer).
 TU,
Bob
*Thanks to: PCNetSpec,emegra for:
http://forum.peppermintos.com/index.php/topic,162.0.html--T23 TOPIC: (SOLVED)Pmint 3, No wireless
** Thanks to:rjm65,PCNetSpec for:
http://forum.peppermintos.com/index.php/topic,172.0.html--T23 TOPIC: (SOLVED)Not working Shockwave Rlash chromium in Pmint3
http://forum.peppermintos.com/index.php/topic,142.msg1037.html#msg1037--T23  TOPIC: (SOLVED)EXPECTED PROB.W/ WIRELESS PCMCIA CARD PMINT3: IN T23 THKPAD W/IN LIVE
http://forum.peppermintos.com/index.php/topic,128.msg829.html#msg829
T23  TOPIC:(SOLVED)Prmint 4 In install solve graphics breaking up in T23 Thinkpad w/in live
**Thanks to:
Ref BiPolarBearprior knowledge base:
http://peppermintos.net/viewtopic.php?f=8&t=6567&start=10
Ref PCNetSpec prior knowledge base:
http://peppermintos.net/viewtopic.php?f=10&t=5373&view=previous
To see attached screenshot:
updated 4/17 ,11:19 http://postimg.org/bobww99
Obsolete ref.
http://postimg.org/image/t1hxsvvi3/451f5cd7/
« Last Edit: April 17, 2014, 11:20:24 am by bobww99 »
« Reply #3 on: April 17, 2014, 06:47:01 am »
What's the output from:
uname -a
bobww99
  • Guest
« Reply #4 on: April 17, 2014, 09:36:41 am »
Hi, PCNetSpec.
From code input:
code:
uname -a
My terminal code output:
bob@bob-laptop ~ $ uname -a
Linux bob-laptop 3.2.0-60-generic #91-Ubuntu SMP Wed Feb 19 03:55:18 UTC 2014 i686 i686 i386 GNU/Linux
bob@bob-laptop ~ $
I have been trying to work this out myself from the little I think I know. I have contacted the Brother web site  (http://support.brother.com/g/b/downloadlist.aspx?c=us&lang=en&prod=hl2270dw_all&os=128 ) and talked to Brother and they did have a download file for:
cupswrapperHL2270DW-2.0.4-2.i386.deb . Not sure if this was correct package to choose.
I down loaded the file,which was auto sent from Chromium to:  /home/bob/Downloads/cupswrapperHL2270DW-2.0.4-2.i386.deb (suspected this was the correct one,but if not, easy enough to delete from my download files in /home/bob/Downloads/ ?) and at this point the automatic helper script came up. I tried to direct the automatic helper to load but I think failed to do so. I could tell by trying to print a doc and it will only let me print to file. I have not tried to enter any terminal commands to download the cupswrapperHL2270DW-2.0.4-2.i386.deb  into the proper place.
So, present situation is :
I have the correct ? cupswrapperHL2270DW-2.0.4-2.i386.deb stored/download file(s) in: /home/bob/Downloads/  .
I apologize, if I created a whole new problem.
Any suggestions ?
Thank You,
Bob
bobww99
  • Guest
(SOLVED) Re: Install Printer with T23 ,Pmint 3
« Reply #5 on: May 01, 2014, 08:44:39 am »
Just an update on Subject. I think I solved the above problem. In a nutshell, I looked into my other computer which has Mint 16. I could print using the setup which was professionally installed. I found that it used the Brother, at least I think it does*, HL 2070N drivers along with the Brother HL 2270DW drivers alongside. I then decided to download the HL 2070N driver to approximate the same condition via the GUI interface. I can print via wired and wireless from Peppermint 3 with no problems. I will mark this problem (SOLVED).
Bob
*The HL 2270DW driver probably is non functioning and taking up disk space. I would like to start a new topic regarding this subject if anyone thinks it might be worth-wild? Feel free to reply if interested. Naturally, you may also ask me how I accomplished the solution in detail and I could give you a little more information.
Re: (SOLVED) Install Printer with T23 ,Pmint 3
« Reply #6 on: May 01, 2014, 09:46:26 am »
Ooops, I appear to have lost this topic .. anyway, glad you solved it :)
