Author Topic: Openbox or Fluxbox  (Read 4558 times)
Openbox or Fluxbox
« on: March 31, 2015, 05:50:18 pm »
Hello Peppermint Nation,
I know it's an understatement to say that I have been very slow to discover this, but I just discovered Fluxbox this afternoon  :); and I thought the safest place I could give it a run, and get some instructions about it, would be here at Peppermint  ;).  But, after I installed it in Peppermint, and after logging out and in, I realized I could never find it to use it  :'(.
I'm thinking that Fluxbox is incompatible with Peppermint.  Am I right about this?
My ultimate goal in using Fluxbox is to help speed up a friend's 11-year-old PC that needs all the help it can get, but I can see that learning about Fluxbox is also a great way to learn more about Linux too.
Thank you,
perknh
« Last Edit: April 01, 2015, 05:02:42 am by perknh »
Re: Fluxbox
« Reply #1 on: March 31, 2015, 06:52:08 pm »
The fkuxbox/openbox/blackbox window managers ARE compatible with Peppermint.. but you're going to be configuring their menu's yourself ;)
In fact early versions of Peppermint had openbox installed by default even though PCManFM was actually controlling the desktop .. you could switch WM to openbox at the login screen though.
Since then we've removed all the preconfigured openbox config files.
Re: Fluxbox
« Reply #2 on: April 01, 2015, 01:00:31 am »
Hi perknh,
I alternate between openbox (very similar to fluxbox, but I find it looks better) and i3wm (not everyone's cup of tea, but I love it). If you are interested in my openbox config files let me know. I started using fluxbox and blackbox and openbox many years back (well, maybe about 10-12 years ago) and preferred them to heavy weights like KDE. I guess one main reason was that I have never owned an up-to-date computer, and back then even the up-to-date ones were sluggish using KDE!
 :P
I never liked XFCE and the new versions have not been able to convert me, so I never use it any longer.
Re: Openbox or Fluxbox
« Reply #3 on: April 01, 2015, 05:01:21 am »
Well, PCNetSpec, I'm desperate here, although in absolutely no rush.  The old computer I've been working on now has Ubuntu MATE 14.02 installed, so it's good for 4 more years. (This is the computer in which you helped me go back to an earlier version of Flash.)  The problem is, no matter what I've done, this old computer is still WAY too slow for comfortable use.
In fact early versions of Peppermint had openbox installed by default even though PCManFM was actually controlling the desktop .. you could switch WM to openbox at the login screen though. Since then we've removed all the preconfigured openbox config files. -- PCNetSpec
I remember seeing some of those things, but default Peppermint worked so fine for me on my computer, I never considered looking at Openbox at the time.  ;)
If you are interested in my openbox config files let me know. I started using fluxbox and blackbox and openbox many years back (well, maybe about 10-12 years ago) and preferred them to heavy weights like KDE. --Slim.Fatz
Well, I've never worked with config files, Slim.Fatz, but if I could learn and play with Openbox here with my Peppermint installation, I could probably transfer what I learn here to that old 11-year-old HP computer that has the MATE installed.  Yes, Slim.Fatz, I could use some pointers here.  I would still need to be able to have the default Peppermint DE too -- since my wife uses default Peppermint 5 as her standard OS, and she uses this particular computer more often than her own.
But yes, Slim.Fatz, if you find me not to be too insufferable, and you're in no hurry, I'm game to give this a go.  ;)
I'm think it will be wise to re-title this thread now Openbox or Fluxbox -- because I think we're headed more in the Openbox direction now.
PCNetSpec or Slim.Fatz, what do you think?  Do you guys think Openbox will help speed up that old computer that has MATE installed?  :-\
P.S.
An update, hours later:
I'm in all sorts of mischief now, I installed Openbox configuration tool, and then lost the close out x in the corners of my Windows!  ::)  I think I'm going to have to re-install Peppermint and start fresh.  This is where one needs loads of patience with me.  I never know what I'm doing when I begin a new project.  I'm still educable, I hope. :-\  This new stuff just takes loads of time with me.
Light and fast windows managers -- these things are all new to me.  And, on top of all this, I'm aiming for something that a very, VERY, cool great-grandmother can use!
« Last Edit: April 01, 2015, 07:17:40 am by perknh »
« Reply #4 on: April 01, 2015, 09:41:20 am »
Hi perknh,
I'm sure that you can get your "close out X"  back in the window corner without having to reinstall the entire OS  :-X
If you send me a private message with an Email address, then I will zip up the config files I use for openbox and you can play around with them.
Openbox under Peppermint uses very little RAM and is very responsive. Ideal for a older, slower cpu and a box with not much RAM. But it is still quite user friendly -- my wife uses it and gripes whenever she visits someone and must use a Microsoft Windows desktop!! :P
« Reply #5 on: April 01, 2015, 10:16:21 am »
Hi perknh,
Hello Slim.Fatz,
I did get back everything without re-installation, but I lost my Openbox tools in the process.  If you don't mind me being a bit monkey here, I'll be glad to imitate everything you do, until I'm able to work Openbox for myself.
Thank you,
perknh
« Reply #6 on: April 01, 2015, 10:58:44 am »
@Slim.Fatz
If you want to email them to me
mark@peppermintos.com
I'll add them as  an attachment in the resources forum
Up to you, but I'm sure people will find them handy :)
« Reply #7 on: April 01, 2015, 11:06:35 am »
Hello Slim.Fatz,
Well that is good news -- and progress at the same time!  I'm not sure which tools you mean. I actually do everything concerning configuration of openbox and conky (which I also use) with my text editor -- in my opinion the tools for openbox are unnecessary and hinder learning how it (openbox) works.
Of course I don't mind at all -- but I'm not sure what your wife and the neighbors are going to say ...  :P
Since my config files are rather long, I will only post the short autostart file here:
« Reply #8 on: April 01, 2015, 11:24:32 am »
@Slim.Fatz
OK, I sent them. Thanks for doing this, and I hope that they are of use to someone.
« Reply #9 on: April 01, 2015, 11:48:21 am »
Quote from: Slim.Fatz
On the contrary, thank YOU :) .. Slims sample openbox configs can be found attached to this posting:
http://forum.peppermintos.com/index.php/topic,1685.msg15488.html#msg15488
Or direct download link here:
http://forum.peppermintos.com/index.php?action=dlattach;topic=1685.0;attach=105
« Last Edit: April 01, 2015, 11:56:22 am by PCNetSpec »
« Reply #10 on: April 01, 2015, 12:42:04 pm »
Slim.Fatz, you have no idea what they're already saying!  ;D
Thank you,
perknh
