Author Topic: Editing grub to change boot order (Solved)  (Read 6572 times)
Re: Editing grub to change boot order
« Reply #15 on: February 22, 2015, 05:29:46 pm »
I'm getting angrier, as I type...   8)
LOL :))
Offline 10i
  • Peppermint Enthusiast
    • My Peppermint Blog
« Reply #16 on: February 22, 2015, 11:14:37 pm »
OK, so I copy & pasted that command into a Terminal window.
Now Peppermint boots without showing me a boot menu where I can choose which OS to boot. I was hoping to still have a boot menu, although I am just about finished testing Mint. So it is not a crisis.
Peppermint user since Fire / Ice
« Reply #17 on: February 22, 2015, 11:39:50 pm »
Hi 10i, how's it going.   Boot up Peppermint.  Run the following command:
sudo update-grubLet it do its thing, then reboot your machine.  You should now have the Peppermint bootloader menu.  I hope this helps  ;).
Offline 10i
Re: Editing grub to change boot order (Solved)
« Reply #18 on: February 23, 2015, 01:41:58 am »
Thanks everyone, it works perfectly now.
« Reply #19 on: February 23, 2015, 01:51:37 am »
Cool,  I know how you were feeling.  I was running Crunchbang alongside Peppermint.  Even though I had dual booted before.  For the life of me I couldn't remember where to put the bootloader and how to update grub.  It was driving me nuts.  It's such a simple thing to do too  ;D.
